Explain this!!??
Old 09-09-2009, 06:44 PM
65fury's Avatar
Explain this!!??
So i took a trip to Utah towing around 4-5k pounds and did between 70-90mph the whole way, except on the really steep hills i kept it around 55mph, anyways during the trip i averaged 13.5mpgs the whole way with a few 14.5mpg runs. My timing was at 15* and i had stock dvs, when i got home i still averaged about 14mpgs everywhere i went, i then installed my laser cut dvs for a lil more power, and still..... no better than 14mpgs. So i upped the timing( a bit to much probably) to 21* and still...... 14mpgs. Except on the highway i can get about 16ish mpgs........ so whats up with my mileage? no matter the timing or amount of fueling i mess with... my mpgs suck!... any ideas? thanks
jason
Old 09-09-2009, 06:52 PM
Mike D's Avatar
My uneducated guess is the 6" lift and tire combo.
Old 09-09-2009, 07:22 PM
65fury's Avatar
hahahahaha...... ya... thats a good possibility.... its just that i know some guys with the same combo and they were running 38's and got 20-21mpg towing i guess unless i got bored and threw stock suspension on my truck... i wont know for sure
jason
Old 09-09-2009, 07:27 PM
trksrfun's Avatar
im sure your speed played a big role in that, what are your speeds now on the highway without towing.... towing at 70-90 will kill mpg while 65 and not towing will help get you more...
Old 09-10-2009, 12:06 AM
65fury's Avatar
Well, when im not towing i do the speed limit 65mph, only reason for the speeding before is i was following people and i wasnt paying for fuel, but no matter the speed or style of driving...... i never get better than 15ish mpgs.
jason
Old 09-10-2009, 09:55 PM
DodgenIt's Avatar
My brothers 96 12v was the same. No matter if towing or driving, he always got 15 mpg. Highway would bump up to 17, but around town no matter what he always got 15. He had that truck for 5 years, Had us stumped.
Old 09-10-2009, 11:07 PM
Lil Dog's Avatar
You built the tranny, what torque converter are you using??
Old 09-11-2009, 02:00 AM
65fury's Avatar
Well i had a custom one built in Idaho at a tranny shop that a friend built, since he knew how my truck ran and the hp i was pushing, but someone screwed up on shipping and i had to have my truck running that weekend for my trip to Utah cause i was towing a trailer... and i had to go with a no name triple disk convertor... from a local shop instead, still cost me $1100 for it too, but its held 500hp, until it started slipping and i just replaced it under warranty, but i had to use another convertor by the same company..... so i still dont like the way it locks up or holds. the company is Recon. Definantly not a performance company in any way... they mostly manufacture stock TC for all makes and models.
jason
Old 09-11-2009, 03:52 AM
matthais's Avatar
I would say speed as well 90mph is dumping the fuel.
Old 09-11-2009, 08:51 AM
YOUNG GUNS15's Avatar
i would say your 435's are killin it also, when i had those on my truck i always got between 13-16mpg and no higher...
Old 09-11-2009, 10:37 AM
Lil Dog's Avatar
Just wondering if that TC is just not working properly. A slipping/loose TC is good for a couple MPG. Do you feel the lock up? IE the RPM drops hard and fast..
Old 09-11-2009, 01:08 PM
65fury's Avatar
Well i wont disagree about the injectors.... although... a while back when i had this same motor setup, and a 3 speed auto transmission and 3.07 gears.. i got 21mpg once... As for the convertor... around town and highway before i lock up... it just sounds like im turning rpms and not going anywhere. Once it locks up it seems to hold and the rpms do drop. Under WOT and locked up.... well i think it kinda slips, but i dont know for sure.
Jason
dcwm
28
05-14-2003 02:42 PM
MnTom
05-03-2003 06:00 PM
RJMontana
03-21-2003 11:20 PM
Dusty 96
12-08-2002 06:40 AM
Quick Reply: Explain this!!??
