EGT's way to HOT
EGT's way to HOT
Any one have an opinion on my egt's this hot, a 2002 dodge 2500 with a edge/attitude, 4" down pipe/5" back and a bhaf intake. My egt's are at like 900 to 1000 cruising around and 1200 to 1500+ floored, but my edge shuts it down. Other than those mods its a bone stock "SO" with 230k, its an Hy turbo i know there junk but they still shouldnt get that high shock!!! Any answers would be greatly appreciated THANKS!!!! Nathan
yea thats hot, cummins says that they can be at 1250 degrees for a while but i know around 1400 degrees is around the meltin point for alimun but its fine for just 5 second burst but dont do it for more that around 10 seconds cause bad things will happen... very bad things
From what I understand high egt's are usually due to too much fuel with incomplete combustion (not enough air). Is your boost where it should be? Is your airfilter clean? Then again, I run a '99 and haven't had any experience with later models.
[QUOTE=ado2b1;2566285]From what I understand high egt's are usually due to too much fuel with incomplete combustion (not enough air). Is your boost where it should be? Is your airfilter clean? Then again, I run a '99 and haven't had any experience with later models.[/QU
The air filter is brand new, with or with out it does it. With the programer on or off they still get that hot!! Do you think it could be a bad injector, leaking or possibly throwing of timing trying to burn that fuel??
EGT's way to HOT
Any one have an opinion on my egt's this hot, a 2002 dodge 2500 with a edge/attitude, 4" down pipe/5" back and a bhaf intake. My egt's are at like 900 to 1000 cruising around and 1200 to 1500+ floored, but my edge shuts it down. Any answers would be greatly appreciated THANKS!!!! Nathan
Air filter is clean by the way its brand new, egt's this hot with and with out edge on!!!
sounds like you could have a fuel starvation problem. when did you change fuel filters? Also you need to check fuel pressure on the incoming side to injector pump. Also you did not state your turbo. Just my guess without seeing your truck.
Happy Truck'n
Happy Truck'n
fuel filter is brand new mabey 1000 miles on it and im pushing 12 wide open and 16 at idle! Mabey injectors bad?
Fill in your sig so we know what truck your talking about.
Is it a stick or auto? Sounds like too much fuel and not enough air.
Do you have the HY35 or HX35?
If you have the HY there's your problem.
Without knowing more details about the mods you've made people would only be guessing.
What injectors have you installed, if any?
What turbo do you have, and what size is the housing? Is it wastegated?
Which Edge fueling box do you have?
Has your computer thrown any codes?
Mike
Mike
Its a bone stock SO. It has stock injectiors stock hy turbo and 230K miles i have a set of injectors and a HX turbo off an HO im going to put on see if it helps any!!
A stock truck with a free flowing exhaust and intake should never see temps anywhere near 1500 degrees.
I think you're probably on the right track when you ask about the possibility of a bad injector. That's where I'd start first. What's the inside of the tailpipe like? Is it dry soot, or is it oily at all?
Mike
Mike
Mike
Mike
Thank you thats what ive been trying to figure out lol!!!!!!!!!!! I have an edge but even with it off there getting that high.Any sugestions??
