Edge Juice with Attitude CTS2
On my 01 I added rv275 injectors then an Edge EZ, and then added a Smarty. I then switched out the EZ for an Edge JWA (the original one not the newer cs or cts). I think at the time it was advertised for 120hp. With everything hooked up and set to the highest level I dynoed 393 hp and 896 tq. The stock truck was rated at 235hp. IIRC stock it dynoed around 225hp. So from stock to the last one came to 168hp increase. I don't remember the stock tq off the top of my head but I am thinking it was 450. so while hp went up 168 tq almost doubled and you could certainly feel it. How much was attributable to the JWA I do not know. I know that the advertised claims of hp and tq gains were certainly on the ambitious side and that as you added the items you could not add up the advertised gains and expect to see that.
If I had it to do all over again I would have stuck with the RV injectors and the ez as that was a solid combo that didn't require changing my turbo etc it was and as many have found over the years a very solid combo and great for towing as well. However we all have different goals in mind when we start bombing our trucks and what works great for one is not enough or too much for another.
I guess all that to say while I doubt you will see 180hp gain you will certainly see a gain and it will be noticeable but doubt it will be 180.
ssobel80
06-16-2016 04:54 AM
Performance & Accessories Edge Insight CTS2 New in Box $225.00
ptm600
3rd Gen All Products
0
01-23-2016 07:24 AM
5.0 Mustang Man
10-21-2008 02:50 PM
razor6
22
01-20-2006 03:43 PM
