Edge comp and TST stacking
Hey guys im relatively new at this diesel performance stuff but I have an edge comp box now and I was looking to stack it. I called edge and they told me to get a box strickly for fuel so I bought the TST pm3 box... How do I install it? and does anyone have that set up and can tell me how it runs bc ive been skeptical about stacking since my edge comp box works so well.... thanks
In order to run both the Edge Comp and the TST, you'll need to remove the wiretap from the Comp at the VP44 and replace it with the wiretap from the TST. At the MAP sensor, you'll need to unplug the Edge harness from the MAP sensor and plug the TST into the MAP sensor. Then connect the Edge harness to the TST harness. So your connections at the MAP will look as follows:
MAP - TST - Edge - Original plug to ECM
Keep the Edge plugged in at the data link connector.
Now you have the Comp hooked up like an EZ and the TST is there for top-end fueling. Make sure you get the order of connections at the MAP correct, or you won't get any additional fueling above 20psi since the Comp does boost fooling.
On top of a good lift pump, I would start thinkin about turbo upgrade too.
Fill out your sig under 'User CP' so we know what else you have done to your truck.
And welcome aboard the never ending mod ride.
rockjeep73
03-25-2005 03:34 AM
Zino
12-16-2003 05:19 PM
mcevins
08-30-2003 11:09 PM
hellotbone
07-12-2003 12:58 AM
