Ecm cuts fuel when sensing "Runaway" myth.......testing complete!
Old 09-02-2009, 10:01 PM
J Lent's Avatar
Rumors been going around that the reason the Redline box pops crackles above 4k rpm is because the ecm cuts power to the fuel system. At 4130 RPM my truck crackles & pops with the Redline box [any setting]. I noticed that when this happens, my fuel gauge bounces off of zero psi. I decided to run direct power to my Airdog on a toggle switch so it can't lose pressure. I tried multiple settings & noticed that the truck seems to want to runaway between 4k rpm- 4200+. It now gets to 4260rpm before it pops/crackles. I figure 100rpm was worth my time. I only tried a few settings, but I think it has more left to it.
Old 09-03-2009, 07:33 PM
Flatbed24v's Avatar
That's awesome!!!!! That's good info to know for those trucks that are fueling above 3800rpm. Some day I hope to be there, either by p pump or vp. Thanks for doing the leg work and giving us feed back on it!!!! Does your quad ADR do the same thing????
Old 09-03-2009, 07:38 PM
JFlory's Avatar
Good find. Now can you confirm that you still have timing advance above
4k rpms? That's the thing holding back the VP. Over 3800rpm or so the pump is advanced as far as it can. The internals just don't let it pull the
4k rpm with the power of added timing.
Old 09-03-2009, 09:07 PM
J Lent's Avatar
I haven't tried the Adrenaline yet. It still won't launch, but it already pulled hard to 4300 rpm. I've been playing with different settings on redline to find the setup with highest revs. I lost by 1ft in open diesel at Greene County PPP pull. 100rpm should get me that foot.
Old 09-03-2009, 09:11 PM
J Lent's Avatar
4300rpm is as far as my vp has been. I know it has advance to that point. If it didn't, it wouldn't pull that far out. I can't wait to see how it does at Listie tomorrow night.
Old 09-04-2009, 03:28 AM
Brokenarrow's Avatar
ok im sure u have seen my post over on comp d but i dont know if this is completley accurate i can take my redline up to 4130 and hold it there and it sounds just as smooth as if u where holding it at 3000, and im using the stock relay.
Old 09-04-2009, 07:19 AM
J Lent's Avatar
Go to 4230 & see when it pops/cuts out.
Old 09-04-2009, 07:55 AM
it wont go there truck only goes to 4130
Old 09-04-2009, 08:03 AM
J Lent's Avatar
At 4131 rpm, you get no cutting out or popping?
Old 09-05-2009, 01:48 AM
Crazydave's Avatar
J, you sent me your 4k tune. I posted a video on the 4k thread on comp d of the truck hitting 4 with the smarty/quad stack. His does the same thing with the quad/smart, it kills the lp power so he also has it on a toggle.
Old 09-05-2009, 09:29 AM
J Lent's Avatar
Got to pull last night. The truck launched smooth finally.
First Hook 373'
http://www.youtube.com/watch?v=Zlkss...e=channel_page
Pulloff 306' first place.
http://www.youtube.com/watch?v=HKYqY...e=channel_page
Old 09-05-2009, 11:29 AM
JIT
JIT's Avatar
Thats AWESOME NEWS!!! Looks like I will be running a toggle to the FASS tomorrow. Thanks for thinking outside the box on this. Good work!
Old 09-05-2009, 11:31 AM
apwatson50's Avatar
I'm not sure how the pump mounts to the case, but could you somehow mechanically rotate the pump to advance the base timing? If you gained 10deg of base timing, then when the pump advances fully say to 20deg you would theoretically have a total of 30deg.
Possible?
Old 09-05-2009, 03:52 PM
J Lent's Avatar
It is worth your time, but don't be expecting 400 more rpm or anything.
Old 09-05-2009, 03:54 PM
J Lent's Avatar
Possible?
I think they already have these, they are called Monster pumps. I'm not sure how far they are advanced though.
Quick Reply: Ecm cuts fuel when sensing "Runaway" myth.......testing complete!
