35s on a dually with no spacers....
Old 03-09-2005, 04:02 PM
Muted User
scarecrow's Avatar
i did it........ i found tires that fit 3500 dually`s without spacers i have them on my truck right now i will try to get pics soon. it is hard for me cause i do not have a digi camera. the tires are super swamper ssr 35x10.5x16 they are a d rated 8 ply tire but the load # is 3415lb per single.which is more then a 235/85/16 E rated bfg. the max tire pressure is 65 right now i am running 50 and i have about a 1/2 maybe a hair more between the two back tires. i am sure that with 65lb of air in the tires they will not touch with a load. also i have a fiberglass cap on my truck so that is alittle weight most of you do not have....
Old 03-09-2005, 05:52 PM
Moose10's Avatar
I'm sure they look good. What's the rated load for duals? I bet if if you put 4k lbs. in the bed of the truck they would touch if you only have a 1/2 inch clearance right now......just a thought
Try to get some pics up
Old 03-09-2005, 07:22 PM
Checkmate's Avatar
Yes, pics, pics. The only thing holding me back from lifting is the **** dually rear end. Unfortunately I have the 17" rims, but if you get 35's to not rub, I'll get some hope for a 17" version.
Old 03-09-2005, 09:04 PM
got...DIESEL?'s Avatar
don't forget about the 37" buckshot mudders.
Chris
wildchild97
31
01-26-2008 05:35 AM
BlueDually
05-09-2006 06:40 PM
97on22s
02-13-2006 09:33 PM
nauitque21
17
05-12-2005 08:50 PM
Agades
23
07-27-2004 09:41 AM
Quick Reply: 35s on a dually with no spacers....
