Dyno, Drag Races, Sled Pull, and Burnout Contest June 26-27 at BIR in Brainerd, MN
1 Post
Brainerd International Raceway on June 26-27, 2010 for a weekend full of diesel competition.
Info on the BIR site here: Diesel Weekend
This is an NRDA-backed event and should be a helluva good time. This event is sponsored by Jags Pro Truck Shop in Zimmerman, MN.
Saturday will be Drag Racing Qualifying and Eliminations. Also the burnout contest sponsored by Midwest Diesel Connection.com will happen Saturday.
Sunday will be the Sled Pull. There will be a portable dyno on site both days from Floor-It Diesel.
It should be a great weekend in Brainerd, Minnesota!
1 Post
JAGS MIDWEST DIESEL SHOOTOUT TRUCK PULLIN CLASSES AND RULES.
Rules that apply to all classes
26" hitch height
3" opening d-ring/Cleves or equal
Dot tires
Drivers are NOT allowed to consume any alcohol before competing. If you are caught you will NOT compete and you will NOT get your hook fee back.
Class jumping is allowed as long as you fit the rules.
8500lbs weight limit for all classes
No passengers allowed in truck while competing.
Trucks that go passed the three hundred foot mark will have a pull off to determine place.
STOCK TURBO CLASS.
Truck must be equipped with stock turbo.
Exhaust must exit reward of the cab.
Not allowed to hang weights.
Rear suspension must move up and down minimum of 2"
No Traction bars.
Diesel fuel only.
2.6 TURBO CLASS
Turbo inlet must not exceed 2.6"
Weight must not exceed 62" from the center line of front axle.
2 1/2 bolts crossed behind turbo in down pipe within 4" of turbo or exhaust must be pointed upward.
Rear suspension is allowed to be blocked solid.
All showing u-joints must be covered.
Traction bars allowed.
Diesel fuel only.
2.8 TURBO CLASS
Turbo inlet must not exceed 2.8"
Weights must not exceed 62" from the center line of front axle.
Exhaust must be pointed upward and behind cab.
Rear suspension can be blocked solid.
Diesel fuel only.
OPEN CLASS.
No turbo size limit.
Multiple turbos allowed.
Hood stacks allowed.
Exhaust must be pointed upward.
Any and all injections are allowed.
Weight must not exceed 62" from center line of front axle.
26" hitch height
Dot tires
STOCK TURBO CLASS.
No Traction bars.
Diesel fuel only.
2.6 TURBO CLASS
Diesel fuel only.
2.8 TURBO CLASS
Diesel fuel only.
OPEN CLASS.
John Rodriguez
51
06-07-2005 11:55 PM
