Tick Tick Tick Tick Tick
Everytime my truck is running I hear a tick tick tick coming from under the truck somewhere Please looking for any insight on this problem.
What year is your truck? When mine was making that noise it almost drove me crazy, until I figured out that it was the mechanical lift pump, on the driver side back of the engine under the fuel filter.
He has a '95.
It could be the lift pump or the overflow valve or it could be normal. Use a long screwdriver or piece of pipe up to your ear and see if you can trace the source.
hey guys thanks helping me with this problem my truck is a 1995 Dodge 3/4 ton 2wd diesel any help will be much appreciated this noise is driving me crazy.
Had both and one was the overflow, which goes away with increased RPM and the lift pump just ticks faster with more RPM. Both easy fixes once you learn what you are doing. Good luck.
If it gets faster with RPM and does not go away then it is the lift pump, if it goes away while driving then it is the overflow, I have had this headache. Drive next to a wall or a curb on the driver side and if you can hear the ticking constantly then it is the lift pump. The return spring in the pump goes out and doesnt allow the pump rod to seat on the cam constantly so it "ticks" as the cam slaps the pump rod. If you have any other questions PM me.
Kevin
Kevin
While the truck is idling, if it is ticking, find somthing that you can push down on the fuel primer really hard with and hold pressure on it, most of the time it will stop ticking, "hint, its the lift pump".
Bought a new lift pump today it should be delivered by monday thanks for all of the help on this onr guys I will let yaw know how it turns out .
MTC
01-02-2008 07:53 PM
stirpicult
34
11-15-2007 08:50 PM
