Stuck in VA
Old 04-09-2017, 12:11 PM
RussM's Avatar
Stuck in VA
Started he truck up this afternoon. Ran about a mile down the road and started acting Edit. Won't get barley any power. About 15% power at full gas pedal push. Idles rougher than usual. From a standstill takes a while to get up to speed. Check engine light is on. E brake and abs light just came on. Air filter is clean. It's Sunday no shops are open and I'm 2.5 hrs from home.
Old 04-09-2017, 01:17 PM
deere country's Avatar
You might get more help if you tell us what your truck is exactly, year, trans, anything done recently?
Old 04-09-2017, 04:03 PM
RussM's Avatar
sorry. 2006 5.9 with a turbo back straight pipe. Read the code. Said P2149. Took the aft injector connection off the valve cover and cleaned it. Ran fine after and made it home safe. Safe to close the thread I think at this point
birdboy
12-12-2018 09:02 PM
birdboy
04-21-2012 09:44 PM
Baja
01-29-2008 08:17 PM
04ctd
09-14-2004 04:43 PM
10-10-2002 05:46 AM
Quick Reply: Stuck in VA
