Trans fitting
Trans fitting
The front drive shaft came out and hit the front transmission line and broke the brass fitting that screws into the transmission and oil cooler line screws into
Does the fitting hold anything in place inside the transmission or can I simply take it out and replace it
Cummins Guru
You can just take it out it is a pipe thread. Try easy out should work to remove it. You are lucky that's all that broke. I have truck in shop now with $15,000 worth damage to it because front driveshaft came out.
DodgeRamdiese01
10-24-2009 04:54 PM
1985cucv
07-18-2008 07:29 AM
ckennedy
11-10-2004 01:03 PM
