n14 cummins ?s
Old 09-16-2007, 08:16 PM
24Vford's Avatar
n14 cummins ?s
does anyone know how much bigger a n14 cummins is than a 5.9 cummins physical size
Old 09-16-2007, 08:18 PM
Registered
blackdiesel's Avatar
ALOT
weight alone would be quite a few times as much not to mention the size
Old 09-16-2007, 08:29 PM
logskidder's Avatar
It would be like stuffing a VW bug under the hood of a Dodge.
Old 09-16-2007, 08:35 PM
Registered
i like that one
Old 09-16-2007, 08:43 PM
Monty's Avatar
855 C.i. 14ltr = N14
359 C.i. 5.9ltr = B Series
Old 09-16-2007, 08:50 PM
24Vford's Avatar
see i saw a truck on the web but can not find it now that was a 1992 ford f350 i belive that had a n14 and 18speed fuller but i was unsure but it could have been an 8.3 but it said it had an engine brake and i was under the impression that that motor did not come with an engine brake
Old 09-16-2007, 09:04 PM
logskidder's Avatar
Thats alot of sawzaw/weld time.
Old 09-16-2007, 10:25 PM
jrs_dodge_diesel's Avatar
I've read about that one. I believe it was the 8.3L C series Cummins.
An N14 is huge. I don't know what the exact dimensions are, but the engine weight is over 2K. Any light duty truck would require EXTENSIVE modification to fit and run an N14.
Old 09-16-2007, 10:33 PM
logskidder's Avatar
I think it may be closer to 4k.......a complete running 855 that is.
Old 09-16-2007, 10:36 PM
96_12V's Avatar
This is the power unit of the Case-IH Steiger 9170
& 9180's as well as many over the raod trucks. IT's over 3k lbs, and not efficient for any type of automotive application (although I doubt you had that in mind...)
Old 09-16-2007, 11:01 PM
gm1276's Avatar
haha - No one even mentioned the idea of a fuller 18spd ... which probably closer to the size to an actual 5.9 than it is to a 5 speed pickup tranny. I had the pleasure, or displeasure of pulling one of these out of a burnt rig in the field this summer, let me tell you it is definitely one big mother, far too big for me to ever consider putting it in a pickup.
Old 09-16-2007, 11:07 PM
Equalizer 2's Avatar
As long as you have a long bed truck it should ride there in the back just fine. Of course a dually might carry the weight better.
Old 09-17-2007, 09:19 AM
gm1276's Avatar
speaking of crazy powertrains though, no joke at macungie this year there was an old International pickup (not a scout, a 1 ton with a service body) with a 3-53 detroit and a 5x3 double club trans. the sticks came up almost to the headboard. apparently it was ordered that way from the factory!
Old 09-17-2007, 07:13 PM
24Vford's Avatar
well i was not looking to put it in my truck i was just curious cause of the ford that i heard had one but then it turned out to be a 8.3 but that motor does not have a engine brake option that i can find
chaikwa
Big Rigs
45
03-08-2017 06:29 AM
haksauto
10-11-2010 01:47 PM
Troutstrannysvc
01-14-2008 10:54 AM
hipsi
10-15-2007 01:30 PM
Engine Girl
06-02-2005 06:35 PM
Quick Reply: n14 cummins ?s
