Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Lubricity Additive Study Results
Old 12-18-2016, 06:38 PM
Dr. Smasher's Avatar
Originally Posted by mikmaze
it gets posted so often it should be a sticky........ but I will add my usual comment. 2 stroke oil was tested, but not at the rate that many of us use it, they used half a quart in a tank( roughly) and most of us use a whole quart in a tank ( roughly) even at the half quart rate, 2 stroke oil did very well, I wish they would repeat the test at the one quart rate.
If he wasn't banned I could ahve told him about one close to him.
motrapper (02-16-2017)
Old 02-16-2017, 08:27 PM
mtnwldman's Avatar
I was told to use ATF any thoughts on this?
Old 02-16-2017, 09:02 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
ATF in diesel fuel is a big no no....old timers used to do it many years ago but ATF composition has changed dramatically over the years....all kinds of additives that are designed not to burn and act as friction modifiers.
That stuff is hard on the newer style high pressure fuel systems and injectors......in my opinion makes as much sense as tossing a handful of fine sand into your fuel tank every time you fill up.
Old 02-17-2017, 08:59 AM
mtnwldman's Avatar
Point taken it was an old farmer that told me. Thanks for the info will have to see if any of the top four are available here in Utah. Then work my way down the list.
Old 02-17-2017, 09:55 PM
ftltmp's Avatar
I use Total Power TPX-HD.
Old 02-18-2017, 06:54 PM
Danderson's Avatar
That's what I run now. Kuboto recommends it and the local equipment rental uses it in their diesel powered stock.
cougar
04-28-2010 09:43 AM
Roany2002
05-30-2008 10:40 AM
coparam4x4
33
10-23-2007 09:32 PM
0
08-18-2003 12:57 AM
Quick Reply: Lubricity Additive Study Results
