86 chevy to 6BT swap? Tranny Kickdown?
Old 04-18-2008, 02:26 PM
transdamws6's Avatar
Hey I am doing a 6BT swap into a 86 K10 1/2ton got the motor all figured out that was a snap but now I am putting a turbo 400 behind it that was in a frito lay truck that had a 6BT in it and I was just wondering if any one knew out there if these tranny's need a kickdown cable? This could be my weakest link!!
Old 04-18-2008, 02:36 PM
alwaysonDTR
Alwaysworking's Avatar
i think they are vacum kick down? and there might be a cable kit you could put on it, that might be the easest way.
if the trannys off a cummins and you are putting it on a cummins it should of been figured out.
Old 04-18-2008, 03:15 PM
96_12V's Avatar
Have you considered the weight? A 6bt is around 1200 lbs, an old 350 V-8 is around 700. Might be a little better as a 4bt, lots of power and potential, and only arond 800 lbs.
Old 04-18-2008, 04:41 PM
The TH400 uses a vacuum modulator to set "throttle pressure" (I guess the frito-lay truck had a vacuum control valve on the throttle linkage to run that) and a kickdown switch to provide a WOT 3-2 downshift. No TV cable.
Old 04-18-2008, 04:53 PM
bigbillyboy's Avatar
I'd like to see some phots of that
I've got an '85 silverado 4x4 with a big block I'd have been day dreaming about converting to a 1st gen 5.9. Love to see some photos of the swap.
Old 04-24-2008, 06:58 PM
See thats what I thought to I thought they were vacuum operated but their is no modulator on on the tranny. I also have seen the electric kickdown switch but how and were would it get wired into the tranny? The weight isn't much of a factor had to go with 6" lift springs also added afew from my old ones to compensate. The motor has 3 mounts the two side ones and a front one. Also boxed frame and made a custom square tube crossmember. Dang thing actually fits pretty good. Thanks for the help will have to do a bit more research!!
Old 04-24-2008, 07:01 PM
Yeah I will work on getting some pics!! new to the site need to get figured out also!!
Old 07-25-2008, 10:24 AM
1985cucv's Avatar
get a different governor and a cable modulator from transmission center .com with the cable!!! mine rips
Old 10-14-2009, 09:33 AM
Greguw's Avatar
I actually posted a few post up , I am in the process of building a 2500 suburban 4x4 that has the turbo 400 , I have a line on a bus that has a 6bt but also has a allison and I was considering doing a devorced mounted transfer ... I think weight would be too much .
Not sure if you 4x4 or not ... just use a 1st gen dodge trans , I'm considering that my self and using a 205 , it has the front drive shaft on the side I need it .
Old 10-14-2009, 05:22 PM
patdaly's Avatar
Pretty sure the frito lay trucks already had the governor in the trans done.
Kickdown would just be a switched 12V applied to the trans.
wicked_sten
Cummins Conversions
12-13-2009 05:18 PM
Bsplyr500
Cummins Conversions
02-11-2009 09:53 AM
curtis73
Cummins Conversions
22
11-03-2008 11:43 AM
93Fury
01-19-2008 02:59 PM
MARKY MARK
02-01-2006 09:28 AM
Quick Reply: 86 chevy to 6BT swap? Tranny Kickdown?
