73 Crew Cab 2nd Gen
#91
I just measured, 3 1/2" from the top edge of the valve cover, to the flat (non-recessed) portion of the firewall. Moving the motor mounts back 1 1/2" - 2", and welding a small extension to the transmission cross member, would save a ton of work on the core support...but then the front drive shaft may need to be lengthened, depending on ride height.
You will also have to modify your steering column to be self supporting, or buy an aftermarket one (which I plan on doing later down the road).
What year/model is your truck?
#93
Those are going under my truck too... I have a set of 05-10 F350 axles sitting on the garage floor. I'm waiting until I've gathered all of the parts to convert the truck to an NV4500, and have everything I need to build the suspension at the same time, so I can do the "lift" and trans swap all at once.
#95
Well, it's been a while since I've been on here. Work has been crazy as well as my twin toddlers. So here's what I've been up to....found a scrap of 10g laying around, and none of my gauges worked, so I handed my wallet to Jegs and got a set of Auto Meter "Z-Series" gauges. A little eyeball engineering and I came up with this:
<a href="http://photobucket.com/" target="_blank"><img src="http://i229.photobucket.com/albums/ee315/LynchHaag/IMG_3011.jpg" border="0" alt=" photo IMG_3011.jpg"/></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i229.photobucket.com/albums/ee315/LynchHaag/IMG_3081.jpg" border="0" alt=" photo IMG_3081.jpg"/></a>
Then I ordered some 315/75R16's on Amazon. $208 per tire and free shipping. They're load range E and they're called the "Repulsor" by RBP (Rolling Big Power). I hope to get the tires installed in 2 weeks.
<a href="http://photobucket.com/" target="_blank"><img src="http://i229.photobucket.com/albums/ee315/LynchHaag/IMG_3097.jpg" border="0" alt=" photo IMG_3097.jpg"/></a>
#96
Well, she went a round the block a few times. All seems good. I've got brakes, power steering and it tracks straight. Now to finish up the gauge install, wiring and front bumper brackets.
%5BURL=http://i229.photobucket.com/albums/ee315/LynchHaag/IMG_3235.mp4%5D%5BIMG%5Dhttp://i229.photobucket.com/albums/ee315/LynchHaag/th_IMG_3235.mp4%5B/IMG%5D%5B/URL%5D
#97
Whoa! I was eyeing this truck for a while. I lived only a few miles away from the guy selling it. Looked like a pretty sound truck from the couple of times I drove by for a peek. Didn't suspect the roof to be in such bad shape though.
You're doing exactly what I would have planned, at least as far as a Cummins swap.
Thanks for the referral. I'd imagine he's mobile, but with a 714 number, he must not be too far from me. I'm in Anaheim and spend time in Cypress as well.
#98
I grew up in Buena Park, lived in Anaheim a couple years ago, and now live in Riverside.
#99
Well, I've been driving it for a while now. She's now running an NV4500/241DHD, adjusted the AFC and ground the fuel plate down. Raced my brother in law with his 04.5 CR with a built auto trans, a tuner and a banks intercooler kit. He only had me by 3/4 of a truck length and I was shifting gears, barking the tires in 3rd, 4th and 5th gears...so I'm pretty happy with the performance (until I have a fat wallet again).
Taking my twins to preschool
Hauling a free 1st gen donor cab
The following 2 users liked this post by 73CrewCab:
patdaly (10-23-2017),
StealthDiesel (10-21-2017)
#101
Nice way to load a free cab in the back of the truck.
#104
the roof was totally trashed with rust and bondo, but I got some good metal off of it, including the clutch master cylinder bracket, and a template of where to put the hole. It also donated an extra automatic brake pedal which became my new clutch pedal after some hoppy chop and welding!
89dieselkong
07-27-2010 10:55 AM
