1974 W200 Crew Progject
Old 02-17-2017, 02:32 PM
  #91
patdaly's Avatar
Originally Posted by BHD
The aluminum grill allows for clearance for the IC but not the AC condenser. If you look closely in post #81 you can see how the aluminum grill attaches to the radiator support next to the headlights. It also attaches to the top of the rad support in about 8 places with screws and it also attaches to the filler plate below the grill, but I haven't attacked that part yet.
So the Aluminum grille holes matched the holes in the top of the IC style support?
If so, that's encouraging.
The Banks IC goes to the outside of the condenser, so if I can get it to clear, it would really clean up the look.
Old 02-17-2017, 07:40 PM
  #92
BHD
BHD's Avatar
No, but they are only #10 screws so, in my opinion its not a big deal to drill a few holes for the top of the grill.
I don't know if your headlights will line up with the aluminum grill, they didn't in the 92 core support as you can see. I would be surprised if it is a direct bolt in piece.
patdaly (02-19-2017)
Old 03-05-2017, 05:03 PM
  #93
BHD
BHD's Avatar
Work continues at a snails pace. I decided to finish the front end this weekend. Specifically getting the filler plate installed with the turn signals. I had to cut the tabs off the donor core support and fit them on this one.
Old 03-05-2017, 05:05 PM
  #94
BHD
BHD's Avatar
Then I needs to cut a little sheet metal to clearance the aftercooler.
Old 03-12-2017, 06:51 PM
  #95
BHD
BHD's Avatar
I acquired a NOS Mack shut down cable and fabbed up a mount under the dash.
Old 03-12-2017, 06:54 PM
  #96
BHD
BHD's Avatar
This is the business end. The cable has enough friction to allow it to be left in the "shut down" position. I had the truck running for a few mins today from the tank with no leaks or other issues. About time!
Old 03-12-2017, 06:56 PM
  #97
BHD
BHD's Avatar
I got ambitious and installed the hood. And learned the bird bath hood will not install without modification to clear the IC radiator.
Old 03-12-2017, 07:03 PM
  #98
BHD
BHD's Avatar
I could use the IC hood, but then I would have to use the 91.5 cowl, and change the wiper stems and on top of that I would lose the awesome birdbath hood with the crusty red lacquer paint that matches the rest of the cab. So I decided to clearance the 1st inner rib of the 74 hood. It fits like a glove!
Old 03-12-2017, 07:12 PM
  #99
BHD
BHD's Avatar
I was dismayed by the amount of rust between the panels on the hood. But overall its better than most for the rust belt. I wonder how new sheet metal is treated, if it is? Will cars built today still be around in 42 years like this W200? Or will they be a corroded pile of rust and rotten electronics?
Old 03-12-2017, 07:34 PM
  #100
Received 2,375 Likes on 1,571 Posts
Nice work getting that intercooled core support to work with the '70 grille and hood.
I have little faith that todays cars will last much more than 8 - 10 years around here in the rust belt.
NJTman (03-13-2017)
Old 03-12-2017, 09:44 PM
  #101
BHD
BHD's Avatar
Thanks Oliver! My next battle is mating the 91.5 hood latch to the 74 hood. HOPEFULLY this is the last body fab work and the rest is nuts and bolts. Except for the bumpers, and then its just lots of welding.
Old 03-14-2017, 01:13 PM
  #102
73CrewCab's Avatar
I used an 89 core support on my 73. Literally cut out a 12" wide (approximately) section from the 73 core support, and the same on the 89....just lined it up and welded it in. Pretty easy to do. There might be a picture in my thread.
-Shaggy
Old 03-15-2017, 02:11 PM
  #103
BHD
BHD's Avatar
I thought about that. But the problem would be the external hood release on the '74 would not clear the aftercooler in the '91.5 core support.
Old 03-15-2017, 02:16 PM
  #104
BHD
BHD's Avatar
First I located the IC hood latch an inch left, and I tacked the bolts in it, just in case it fails in the future, I can access the nuts thru the grill.
Old 03-15-2017, 02:19 PM
  #105
BHD
BHD's Avatar
Then i busted out the Snap-On air hammer and adjusted the sheet metal next to the hood catch. I also fabbed up a crude hood release out of 0.0125" rod that is accessible thru the grill.
Quick Reply: 1974 W200 Crew Progject
