Left Tail Light Issue
I have a 2011 2500, the left tail light has an issue that I can not seem to figure out. First it is dimmer than the right, and the blinker works but not like it should, then when you press the brake the reverse lights come on, when you put it in reverse the whole left tail light goes out, the over cab light works fine, the right tail light is fine except when you brake the reverse light comes
What I have tried:
Replaced bulbs and sockets, traced all wires to the wiring harness to check for shorts, changed fuses and checked fuses
Anyone have any ideas?
What I have tried:
Don't know if the 4th gen are the same as the 3rd gen, but there were a lot of similar issues on the 3rd gens. The problem in most cases were the tail light circuit strip in the tail light. If yours has these, try switching them left to right and see if the problems follows the switch.
Genos has replacement strips.
tack514
04-18-2019 08:46 PM
DodgeDawg2500
08-30-2013 03:24 PM
Valv
12-17-2008 01:40 PM
