H&S Updater exe file
does anyone have the h&s updater exe file that they could send me.. I need to update my minimaxx to use as gauges since im now running efi live..
H&S Performance Files - Mega.nz
Let me know if the above link doesn't work. I tried it from my phone, but not certain if that was the correct share link. If it is, just drill through the folders and you will find the Updater.exe file you are looking for.
Note, all files are on my mega.nz account, so it's not some random link...just not certain if it's the right share link. Let me know if it's not and I'll get on the computer to get the correct link.
The following 2 users liked this post by 6.7L MegaCab:
warrentapp (04-07-2022),
wyokaboy (03-14-2018)
I just downloaded the updater.exe file from the above link, inserted a blank SD Card, selected "Mini Maxx", clicked on "Use Blank Card", selected the "Cummins 6.7" from the next list, clicked on "Find Updates", once complete it will say "Found 237 files need to be updated." (it may find less files if you are using the original SD Card), then clicked on "Update".
It worked fine on my end.
You may need to turn off a fire wall/antivirus, but I've never had to do that. I'm currently using McAfee VirusScan Enterprise.
Sorry if this is a stupid question, but how would I find out if my Mini Maxx needs updated? It seems to work fine other than losing the EGT probe setting once in a while...
If it is working fine, some folks say to just leave it alone. Otherwise you could just download the updater and let it scan the SD card to see if updates are available. H&S shut down their website and took the update history with it.
Should I update
Could this be the cause for all my engine codes lately
RJOS
18
06-22-2007 06:57 PM
KwikKurt
01-30-2003 01:58 PM
