Dual Fuel Filter Kit
I finally got around to ordering a fuel kit for my truck. I'm waiting on delivery from Throttle Up Industries. I purchased the dual Baldwin/water separator and the Cat fuel filter. I figured with this and my Nanonet filter I can eliminate most all contaminants/water from entering my expensive injectors. I appreciate any advice I can get from somebody who has installed this or similar set up. Blake and Lary advised this a while back and I'm just now getting around to it. I have a few questions, Thanks in advance.
1) Install looks pretty basic. Any tips?
2) Will my fuel pump supply enough pressure after the filters are installed at WOT, with a programmer?
3) Kit will be installed near frame under my truck. Any pros/cons of this set up?
4) Cat vs. Donaldson fuel filters. Is one any better than the other?
5) Baldwin Water Separator filter. Good/Bad? Anything better?
6) Anyone done business with Throttle Up Industries?
7) Truck has 69K miles on it. I've never used fuel additives and the truck runs great. Should I start now, for better injector lubrication?
Rick
Rick
Finally installed, only issue was removing the coating on the fuel line. Throttle Up Industries has a good product with easy to follow instructions. I recommend this product for anyone who wants to have peace of mind about what is going through your Injectors.
I pulled the boat this weekend and no issues with fuel pressure.
Rick
GotStacks
05-23-2009 12:08 PM
DNRCustoms
11-11-2008 08:25 PM
