4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
manual transmission turbo/ engine lag? in 2500 diesel
Old 10-20-2016, 11:16 PM
biggranite21's Avatar
I'm a first time diesel owner. I've always wanted one especially a stick. I've got what I wanted which is a 2500 diesel manual transmission crew cab long bed. I freaking love it. One downside to the truck is that I have the least power in hp and lb/ft out of the diesel group. My main concern though is that I experience somewhat of a turbo/engine lag going through 3rd to 6th gear. If I were to floor it after shifting into the gear properly the RPMS would race up and the truck itself would take time to "catch up" or respond if that makes sense. I've explained this to the dealership I bought it from and the diesel mechanic said hes seen this before with other sticks. His explanation to me was that in a stick when shifting between gears the turbo spools down and then spools back up when shifted into the desired gear. In an automatic the turbo is always spooled up for immediate response. I was satisfied with the explanation but I feel like there is something more to it. So I'm getting on a forum to see if anybody out there that has a stick is experiencing the same type of issue because it is the one thing I can't stand about the truck. I know a tuner might help but I need to find out first if this isn't just my truck basically for peace of mind. thanks for your time
Old 10-21-2016, 10:06 AM
saggonwaggon91's Avatar
Turbo lag is what you are getting. Nature of the beast with the manual trans. A tuner will help a lot and raising your shift points will too. Everytime you let off the accelerator, you will lose boost. If you want it to spool faster, keep your RPM above 1500. Thats about were the cummins starts making its power. Also, fill out your sig so we know what you are running.
Old 10-21-2016, 12:27 PM
NJMurvin's Avatar
My truck is a 3rd gen auto, but I've owned plenty of manual transmission equipped cars in my life. Maybe there's some new technology I'm unaware of, but in my day, the above symptoms would sound like a slipping clutch (RPMs racing and truck trying to catch up).
Old 10-21-2016, 02:01 PM
SOhappy's Avatar
Originally Posted by NJMurvin
.... the above symptoms would sound like a slipping clutch (RPMs racing and truck trying to catch up).
^^^What he said. Sounds like clutch slip to me.
Old 10-23-2016, 10:15 AM
guess i didnt catch the rpm racing. lol.
does sound like a slipping clutch
Old 10-24-2016, 08:56 PM
Danderson's Avatar
Yep. Time to call Southbend.
I've had the SBC OKHD for a couple of years now. Smooth and holds my EFI mid tunes fine.
Old 10-30-2016, 08:18 AM
Rollin'_Coal's Avatar
+1 slipping clutch. Might be time to find a new mechanic.
blueberry
01-11-2006 12:46 AM
crossy
07-14-2005 05:55 AM
ptextreme
03-21-2005 02:02 PM
MY WORLD
26
02-26-2005 06:47 PM
J BODY
06-08-2004 07:16 AM
Quick Reply: manual transmission turbo/ engine lag? in 2500 diesel
