4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Diesel Starter Not Turning
Old 03-15-2017, 10:36 AM
cswin's Avatar
I have a 2014 RAM 3500 with the 6.7L engine. Recently, I began having an issue starting the truck. When I turn the key, the starter will not turn. The voltage is 12+ on both batteries and everything else in the truck works fine of course. I can only start the truck when I jump it. I removed both batteries individually and charged them for 24 hrs. After doing this, I had the same result - truck wouldn't start.
Is it possible that a truck this new would have bad batteries already? Is there another step I can take in troubleshooting this?
Thanks in advance for your help!
Old 03-15-2017, 10:39 AM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Yes the batteries could be bad...take it to a auto part store like Advance or Oriellys they will test them for free. If they are bad you must replace both at the same time a bad battery will quickly kill a new one.
cswin (03-15-2017)
Old 03-15-2017, 11:07 AM
Mexstan's Avatar
Place a voltmeter on the batteries and have someone turn the key. If the voltage drops dramatically, then it is probably one or more bad batteries. If no voltage drop when the key is turned, then the problem is somewhere else.
Let us know what you find.
FMB
11-14-2010 09:09 PM
12valvesmoke
06-12-2009 09:46 AM
buckman361
11-13-2008 09:54 AM
dieselrob
09-01-2007 08:13 AM
Paradise Racing
01-18-2005 09:08 AM
Quick Reply: Diesel Starter Not Turning
