4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
installing a new transmission oil pan
Old 03-08-2017, 06:42 PM
mikey59's Avatar
I'am going to install a new afe transmission oil pan and my neighbor was saying that he wouldn't do that because of the thermostat that's in the tranny it would cause it to run at a cooler temp.is this true? i was told that having a cooler tranny is what you want in a tranny even if you r not towing anything. I'am open to any ideas on this. Ive already purchased the tranny oil pan . I have a 2012 6.7 with a 68RFE six speed
Old 03-09-2017, 07:38 AM
Just a plain ole guy
1-2-3's Avatar
first, isnt it funny how the meaning of words have changed. Merle said it best in his song, i wish a buck was still silver..
Your not going to hurt anything. Your going to prolong the life of your tranny. Your going to have more oil so you'll get better life out of your oil. The ONLY drawback I see, is the built in drain plugs. People tend to drain the oil and refill it. Once you drain it, without the mess this time, make sure you drop that pan and look inside for signs of failure and premature wear and change the filter.
You shouldn't have any problems with ground clearance. I'd like to change my pan too.
Old 03-09-2017, 04:31 PM
Busboy's Avatar
On my 2011 68RFE I installed a finned aluminum pan with a drain plug when I changed the transmission oil for the first time. It lowered the transmission temp 10-12 deg, I have gauges so I can monitor when towing heavy or towing in the mountains. The drain plug enables you to drain the oil BEFORE dropping the pan to change the filters, it's soooo much cleaner this way and I would recommend it in a second.
Old 03-11-2017, 08:33 PM
mikey59's Avatar
Lightbulb
Gages ,transmission pan and cooler are my next devices that iam installing. I looking at the db trans cooler with 80 watt fan and double pass heat exchange with 40,000 btu.my transmission pan is afe finned pan (machined) with an extra 3 to 4 quarts . this should really help get read of the heat
Old 03-13-2017, 06:00 AM
1-2-3's Avatar
You already have a transmission cooler. Factory installed.
EverydayDiesel
11-11-2007 09:33 AM
tex23455
07-25-2007 02:31 AM
bostongsx
09-25-2006 11:25 PM
betsycam
19
08-19-2004 08:30 AM
Quick Reply: installing a new transmission oil pan
