check engine light
check engine light
anyone can help me out that would be great ! i have a check engine light on a 2015 ram 2500 slt 6.7 for diesel air flow position sensor ? can i stilll drive the truck? and what is it lol thanks
Cummins Guru
Covered under warranty take it to a dealer. If the valve doesn't open and stays closed that will cause a no start. Engine will crank over like it has no compression, no air will be able to get into engine for combustion. Best to have it replaced ASAP. The valve causes a pressure drop across EGR valve to control EGR air flow. Very important that this emission device works as designed for proper engine operation. Valve is part #5
brandonguarrasi (01-17-2017)
buddy26
02-15-2008 12:17 PM
choppers555
10-16-2007 12:29 PM
alltimelow1
04-06-2005 07:28 PM
Fillerupsonny
10-09-2002 06:01 PM
