4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Bed does not drain water .
Old 01-19-2017, 05:34 PM
dewclaw's Avatar
I bought a 2010 used and the guy had a spray in bed liner . Did they plug some holes before spraying then forget to remove the plugs ?
My 98.5 had drain holes one on each side towards the front .
Its not a big deal but when I park facing downhill , the front of the bed fills with water then with our latest weather it freezes into a solid block and I have to haul it around everywhere !
Maybe I am missing something ? I know , I am from California so I am missing half my brain right ? ; ) I am from WAY northern Ca though if that helps....in the Deep woods ... way away from the granola crowd , yunno , the nuts and fruits.......
Thanks in advance ,
Dew
Old 01-20-2017, 07:41 AM
sherod's Avatar
They probably filled the front drains. Bet if you look from underneath, you can find them without just poking random holes.
Old 01-20-2017, 11:33 AM
dewclaw's Avatar
Yep , will do as soon as it quits snowing . Thanks Sherod
Old 01-20-2017, 02:42 PM
Busboy's Avatar
After I had the box liner sprayed in on my 2001 I used a pointed 3/4 inch diameter punch and drove it through the existing drains as they were almost filled in, on my 2011 I didn't get it lined but the drains do sometimes get filled with leaves and crud..
Old 01-21-2017, 05:39 PM
gsbrockman's Avatar
Thanks in advance
Try parking uphill????
Old 01-21-2017, 08:32 PM
dewclaw's Avatar
Hey wow !!! Never thunk of that that !!!! Us Kalifornians aint that quick ; )
I did think about selling some blocks of ice ......just tryin' to figger out how to keep it solid till summer .......
Kinda lol'in
Dew
Old 01-30-2017, 01:31 PM
dewclaw's Avatar
Well, the drains are actually narrow slots in the front corners of the bed, near the cab. The spray liner semi plugged them up , I scraped out some of the liner material , they drain fine now.
BTW , sorry for posting in the Engine and Drive train section. My bad .
Dew
1985cucv
04-06-2010 08:05 PM
Mark Hodowanec
09-25-2007 09:58 AM
LightningMqueen
04-24-2007 08:57 PM
wooff
05-01-2003 11:22 AM
Quick Reply: Bed does not drain water .
