4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Anyone successfully using the 10w30 semi-synthetics?
Old 07-15-2016, 03:40 PM
streetsmoker's Avatar
I'm just curious to see if anyone here is currently using the 10w30 multi-blends such as Rotella t5, Delo XLE, or Delvac Super? If so, at what point do these begin thermal breakdown, add I know the full synthetics handle higher oil temps better. Thinking of switching to this for the added increase in mileage it claims to provide.
Oh, and this is for a different truck than the one in my signature. As its been a while since I updated.........LOL!!!!
Old 07-16-2016, 07:48 PM
MikeyB's Avatar
Living in the deep south I would stick with 5w-40 or 15w-40 in the Cummins. 10w-30 would be fine in the winter months in the frigid north.
Old 07-19-2016, 06:05 PM
Harvie's Avatar
You do not need to spend the extra money, straight Rotella 15-40 works just fine and at 12.97 a gal at wallymart it can not get any better then that.
Old 07-19-2016, 09:13 PM
Busboy's Avatar
Actually in the "frigid North" paper version of the owners manual it states that engine damage may occur if 5W 40 is not used in the winter months. I just run it year round towing heavy.
Old 07-28-2016, 11:00 AM
ofelas's Avatar
I believe a 30w was Cummins fill until 89 or so.
Modified to a 40w soon after as most mineral multigrade 40w oils would shear down to a 30w anyway (a multigrade 30W would sometimes shear down to a 20W).
A semi synthetic or full synthetic 30W would do just fine, as flow is what protects bearings more than pressure does.
Not to mention a 30W is likely better for turbo bearings & piston cooling nozzles.
Old 07-28-2016, 01:39 PM
rjm022's Avatar
My neighbor has been a heavy equipment mechanic for many many years. He also has an 04 Cummins. He uses semi synthetic 10w-30 oil since he bought the truck new. Truck has 130,000 miles on it. Says most the heavy machinery he works on also uses 30 weight oils
1STGENFARMBOY
02-11-2016 12:45 AM
Spooler
07-07-2012 10:32 PM
sallyman1
26
03-02-2009 02:32 PM
BIGBEN
10-02-2007 06:22 PM
wilderness
13
09-25-2006 11:59 PM
Quick Reply: Anyone successfully using the 10w30 semi-synthetics?
