4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
Rpm drop
Old 11-24-2016, 04:55 AM
Celestine O's Avatar
Rpm drop
Please I need help on what to do. My diesel truck was almost empty if not empty so I was luck to find a close buy diesel station but after buy diesel I drove for about 30 minutes to 45 minutes then my Engine check light came on and my RPM suddenly begin to drop. I stopped and state it again and it start and drove fine but after ever few 5 miles it will drop, I will pull over , turn of the engine and wait for 2 minutes then start the engine. Finally I drove it for 2 hours staying on just 50 mph. Please guys what must have cause this to happen and how can I fix it.
Old 11-24-2016, 09:54 AM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Go to auto zone or parts house pick up a code reader. That would help to diag your truck. Possible contaminated fuel since it started after filling up. Keep your fuel receipt just in case it was bad fuel and caused damage to fuel system.
Old 11-25-2016, 07:39 AM
saggonwaggon91's Avatar
Also check your fuel filter. That close to empty, you may have sucked up some debris and its clogging the filter. Shutting it off may just be letting it settle in the bottom of the filter bowl then the restart and drive may stir it up again
Old 02-11-2022, 09:34 AM
RanniWins's Avatar
You need to urgently contact a service center or try to count engine errors yourself, but it’s better to try a wall work service center. Most likely contaminated fuel, as the problems started after refueling. If you still have a check and can prove that the problem is in the fuel, you'll have a laboratory conclusion, then you can safely go to the gas station with a claim. Although the reason may not be in the fuel, if coincidence, but here you just need to check all the systems.
Old 02-12-2022, 01:23 PM
nothingbutdarts's Avatar
^ ^ ^ ^ ^ ^ Just pointing out, this thread hasn't been posted in since 2016
Required_Field
28
06-30-2017 07:27 PM
rick39
11-30-2015 05:19 PM
turbotona
09-04-2007 10:14 PM
justramit
44
03-07-2007 09:21 PM
Twisted Shifter
27
05-09-2005 07:37 PM
Quick Reply: Rpm drop
