a/c blowing out rear seals
HIeveryone iIhave 06 5.9 new compressor new dryer new orifice line if iI ad 1 can freon it gets cold but after about 300 miles rear compressor seals leak freon out ? Replace seals same thing ? Thanks in advance help pete.
It would bes best if you had a set of gages
Hi, It would be best to have a set of gages to confirm your high side pressure is in range. Confirm that you are, lubing the oring with refrigerant oil and torquing the bolt that attaches the lines to 23 Nm or 17 Ft Lbs. You may also try the R134a with the dye in it to find the leak.
greasy
12-12-2004 10:24 PM
