blower fan won't work
On my '05, the blower fan quit working and stayed that way for several weeks. I checked fuses and everything else I could think of and found nothing wrong. After all that it started working again on its own. I think everything else still worked ok.
What do I need to do or check to try to prevent that from happening again?
Also, is this a common problem for these trucks?
Thanks for any help.
Yes, it is a common problem. The power for the blower motor comes directly from the ignition switch. YOu need to pull the steering colmn cover off and check for burnt wires at the ignition switch and the connector. Many folks have had this issue and we always see a handful of these in the winter time. If you have no bad connections, replace your ignition switch (just the switch part).
I have very similar problems as well. Mostly mine quits blowing during the summer when it's freakishly hot.....get to the next location and shut it down and start it back up and low and behold it's working again. I also have the issue of sometimes the hvac modes work and sometimes they don't. Any thoughts on that one?
hey jhenson, i'm going through the exact same problem with mine. dodge seems to think its the box under the dash that directs the air from either the defrost to the vents. i don't believe it is though, but they told me that the box is 43 dollars but the labor is over 600 imagine that. i guess i'm going to break the ol steering column apart and check that first. if you find anything else out about yours jhenson, would you let me know.
I have had intermittent issues with my ignition switch over the years too. If I turn it to accessory you have to wiggle the key around to get the stereo to play and whatever you do don't touch it once it does start playing because once it goes off the whole aggravating process starts all over. I have also noticed that sometimes when I start the truck the stereo won't play either but if you shut it down and start it back up, "poof", it works again. Maybe the hvac issue is contributed to the switch after all. Maybe I'll figure it out .
Jim Lane
04-05-2020 06:03 AM
