3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
undeleting 6.7
Old 12-01-2016, 07:40 PM
Navy7797's Avatar
undeleting 6.7
2009 6.7 dodge Ram 2500 deleted @ 50k Un-deleted @ 243,000 miles
Having to take truck to dealer I was force to un-delete my smarty from the truck. I replace and plugged everything back in and the dealer was then able to find that the engine harness was bad causing my miss/buck in the engine. All was good for the 1st 5 miles, than came the codes.
DPF full
low NOX/DPF filter line pressure
When I put the NOX filter and DPF back on the truck I connected the pressure lines to the switch on the side of tranny but not sure there in the right position. One line comes from the NOXfilter and the other from the DPF and are connected to the switch bolted to side of the tranny and a wiring harness is plugged into that.
Which line goes to which side of the switch. Thanks for the help !!
http://redirect.viglink.com/?format=...%20Forums&txt=
Old 12-07-2016, 08:58 AM
Navy7797's Avatar
figured it out myself thanks to those that looked.
Old 12-07-2016, 02:32 PM
"California Style"
mega-engr's Avatar
I was not sure it mattered which pressure line went to which side. Was this your issue?
