White Smoke - Black Smoke
Bad Injectors!
Last Friday my truck did something I have never seen her do before. After the truck had been sitting for a couple hours, I went to start it and had a good amount of white smoke billow out of the exhaust while in park. After a watching if for a day, here is how the smoke plays out:
1. Start up = White smoke
2. Idol in park = fairly clear
3. Idol in drive = occasionally random puffs of noticeable white smoke.
4. Acceleration = Mix white and black smoke
5. Revving the engine in park = Mix of smoke, almost looks brown
You can see what I have in my sig…any suggestions?
Thanks in advance for the insight.
Mine is doing the same thing But When idle it is shakes when cold ,Had it to the dealer, they say nothing wrong ! If computer says it good ,Then they can not fix it . I Have about 14k on her ! Already Lost # 4 Piston And a Head ! This Is My 5th Dodge Cummins And I Hate to say my Last !
Regards,
T-B
Regards,
T-B
pull off your intake tube and see if your turbo shaft has any movement in and out a little up and down is ok but in and out mings a worn out bearing and the white smoke could be oil from that bearing.
recone5
11-05-2008 10:26 AM
RJOS
16
09-03-2007 09:19 PM
BlackSheep5
11-27-2006 07:52 PM
onearizoldman
06-29-2005 08:24 PM
