We Love Trucks
Vendor - Former Vendor
We Love Trucks
Do you wreak havoc on your truck’s floors or keep them sharp? Either way you love your truck.
Michelin EdgeLiner creators also love their trucks. That’s why we take great pride in making our liner into one that we use.
Backing We build Michelin EdgeLiner with an aggressive nib pattern combined with ribbing, retention posts, and rolled edge technology to make sure it stays in place and holds its shape.
Flexibility and Stability You will undoubtedly be taking your EdgeLiners out to clean them over and over again. The flexible, rubber-like nature of our liners allow you to remove them easily, without spilling the contents. That same flexibility means that they will return to their shape when you set them back on your floor.
Depth Other floor liners barely scratch the surface of our impressively deep grooves and cavities that can handle much more slush and mud.
Materials We build our liners with a rubber-like substance called TPE instead of the plastic polymer used in other floor liners. TPE not only stands up to wear and tear better, it stands up taller, letting us craft deeper channels.
The Michelin EdgeLiner is more than a layer between your feet and the floor; it’s a strong, removable base that can be dumped, washed, dried, and put back better than new.
Different Materials, Different Process, Better Results.
We can ship from www.EdgeLiner.ca
SmittysRam
35
08-10-2011 11:06 AM
FireNhole
01-11-2003 06:56 PM
