Grid heater/Stock airhorn delete
Living in a climate where it's warm/HOT! 9 months out the year I've decided to eliminate the stock grid heater while building my own 3" round tube intake airhorn for better flow. Now the question is, can I get away with having only one battery? Thanks, Dave.
I'm running dual red tops right now and also have 2 yellow tops that are not being used. I thought I'd try 1 yellow although they don't like to used in short bursts like the red's according to Optima.
The yellow-tops flat out suck as a starting battery. I bought one of the biggest sizes they have and it won't even start my Toyota on a cool day.
Why do you need to remove 1 battery for a grid heater delete and aftermarket air horn anyway?
If you are trying to gain some additional room under the hood, you could re-locate the battery/s (Optima) against one of the frame rails under the cab. I have seen this and it worked well. The optima does not care about what position it is mounted in so there should not be any issues.
One of the main reasons for having 2 batteries is for the amp draw of the grid heater. I understand that having 2 batteries would give me a longer reserve while cranking the engine if I ever had problems but I don't see the need with a CR. If it dose'nt start there's no need to keep cranking untill it's repaired. Call me it's ok.
Have you ever looked inside the stock intake airhorn. It's a joke! 3"x1.75".
I thought the real reason most diesels have 2 batteries is to help start the higher compression engines?
awenthol
03-02-2009 08:34 PM
53 willys
34
05-09-2008 02:46 PM
Erik@LCD
83
01-24-2008 08:51 AM
CL2000
31
07-17-2007 02:25 PM
