Getting ready to install my new BD Exhaust Brake - Dodge Diesel - Diesel Truck Resource Forums
Thread Tools Search this Thread
Old 03-06-2017, 09:53 PM   #1
thenrie's Avatar
2005 3500, 5.9 Cummins, manual, BD turbo-mount Exhaust Brake.
Looking at the instructions, the wiring diagrams make it look like I can eliminate the entire DFIV installation by using the shifter-mounted rocker switch I bought. Yet the instructions clearly indicate installation of the DFIV module before it says to jump to the rocker switch installation.
Do I have the option of eliminating the DFIV module? Should I?
Any input as to preferences? The DFIV would give ma a gas pedal actuation and a cruise control disconnect, but then if I have the rocker switch, would I need those?
Second question: What options have people looked at for replacing the tiny little compressor with a better unit that would be usable for tires? This little thing has a 150psi max pressure, but only a 25% duty cycle at 2.3cfm at 100psi. Wondering if I might be able to install a pressure tank up under the frame that would hold enough volume at 150 psi to fill a tire or two.
thenrie is offline   Reply With Quote
Old 03-10-2017, 06:49 PM   #2
I'm getting ready to install a Pacbrake on my 07, and have decided to do the air system myself. I would recommend getting a better compressor, look at some of the stuff sold for cars with pneumatic suspensions. Viair makes some Compressors
I picked up a pretty big one and have mounted it under the passenger side with a big splash pan to protect it. There are many other brands as well. Amazon and Ebay have a big selection size and shape tanks, there's plenty of room under the truck to stash one.
esde is offline   Reply With Quote
Old 03-18-2017, 09:20 PM   #3
thenrie's Avatar
I've been working on installing my BD exhaust brake most of the day. Unsuccessfully. The instructions are poorly written, to the point that I'm not sure whether I'm missing parts, or they shipped me the wrong item, or I'm just stupid.
Before I burst into flames here, I'm going to call them next week and see if Diesel Power Products and BD will get me straightened out and squared away.
Old 03-19-2017, 08:38 AM   #4
Mexstan's Avatar
I have the Pacbrake on mine and only use the stick mounted switch. It is positioned so that I can activate it with my thumb and use it many times every day. You do NOT need all that electronic stuff to control the brake as that is optional.
As for compressors, I now use two Viair compressors mounted in the box in the back of the truck. Made a semi floating installation for sound deadening. Originally I had one compressor installed behind the back seat, but that was horribly noisy. Now can no longer hear the compressors when they run, so installed a tiny LED on the instrument panel next to the pressure gauge so that I know when they are on.
I have a Viair 2.5 gallon air tank mounted under the LH side of the truck between the frame and the side of the cab. Also have a Viair 5 gallon tank squeezed into a similar location on the RH side and connected in series. Next to the rear seat and inside the truck I installed a standard quick disconnect so can now use this air for other purposes like pumping tires.
The photo shows my compressor installation. I have the extra valving that is required for the front and back airbags, but you will not need them. If you install a compressor this far away from the battery, make sure that you have an adequate wire size for the load and a proper fuse next to the battery.
Mexstan is offline   Reply With Quote
Old 03-25-2017, 10:27 PM   #5
thenrie's Avatar
I got my BD exhaust brake installed...finally.
I called the tech rep at Diesel Power Products. The man said that if I do not install the DFIV module, even though I will be using the stick shift toggle switch, I risk damaging the engine if I should push the accelerator while the EB is engaged. I decided to go ahead and install it.
I followed the directions to the T, including soldering all the connections, rather than using the included quick-connectors. Got it all installed and everything works as advertised. I'm pretty pleased with the unit.
Now the review:
First, I ordered the unit from DPP online. I have purchased several items from them in the past and have been very satisfied. However, this time I received the confirmation of my order, but no shipping details. I noticed my account was charged for the purchase immediately when I ordered. After several days I contacted DPP to find out why I had not received any tracking information or confirmation of shipment. I was informed that the item was backordered and would be delayed about two weeks. I asked if it was their practice to charge the customer before the item is shipped. The receptionist answered that the charge is how they process their orders. So, if the item is backordered, the customer is charged immediately, regardless of when the item actually ships. I was disappointed in that policy. Most reputable places will give the customer the option of refusing the sale or waiting for the backorder and will not charge the customer until the item ships. Happily, the EB arrived sooner than expected.
However, when I opened the package I found it was poorly packaged and
EB had sustained damage. Apparently the box was dropped in shipping and a fitting had been broken off the actuation cylinder. The box did not show any apparent damage. Additionally, the air filter for the compressor was not included in the order, although I did get a used cigarette lighter. I contacted DPP and a couple days later they followed up by mailing me the broken fitting and the filter assembly. That was at my request, since I had the necessary tools and skills to extract the broken fitting from the cylinder and install a new one. Otherwise I would have had to return the entire package and wait for another.
Later, during installation, I found they had also failed to include the anti-rattle pad which backs the compressor bracket. I called again and they are supposed to be mailing one out to me. I went ahead and finished the installation and will install the pad after the fact when it arrives.
Lastly, the installation instructions provided by BD are unclear. The unit is for 2004.5-2007 trucks. The instructions flow through the installation process by breaking out sections designated for 2004, 2004.5-05, and 2006-07, however in various places it is hard to determine whether a particular section applies to all or just one of the various year models. When it comes to the stick shift push-pull and toggle switches, the instructions and diagrams they provide apply only to the 2006-07 year models, but the instructions don't actually say that, which is what occasioned the questions above and my telephone call to DPP.
The BD product is obviously a high-quality unit. The EB itself is a very heavy hunk of cast iron with a very heavy steel butterfly valve inside. All mating surfaces are well machined and smooth. I was very pleased with the quality of each part of the unit and with the connectors, wiring, and other parts included with the kit. It installed quite easily, well within the capabilities of a reasonably capable shade-tree mechanic (I put myself in that category) and did not require any special or unusual tools. A good soldering iron and a multi-meter are helpful, but not required.
I don't believe Diesel Power Products is to blame for the missing parts in the kit, and I am sure they didn't write the installation manual, but all that was disappointing, nonetheless, for a $1300+ purchase.
I haven't yet had the chance to test the new EB with my trailer, but look forward to doing so. I have spent nearly $2500 over the past three years for brake work on my truck. The last time, the tech said I need to check the brakes on my trailer, because my truck brakes were getting over-heated. I told him my trailer brakes were new and recently adjusted and that I have a very good brake controller. I am hoping my new EB will help reduce the costs on my brakes sufficiently to pay for itself over the long haul, besides making hauling my horses in the mountains much safer.
Side note: The clamp bolts on the turbo clamps are very easy to break. It would seem reasonable that Dodge would have a supply of those available, but no. The bolts can only be purchased from Dodge as part of the clamps, which run about $65 each. Rather than do that, and lacking any other source for the T-bolts, I made my own out of a couple stainless steel 1/4" fine-thread bolts, locking nuts, and a couple short pieces of 3/8" steel rod. They worked just fine for a couple bucks and a few minutes of work.
Getting ready to install my new BD Exhaust Brake-img_2858.jpg   Getting ready to install my new BD Exhaust Brake-img_2859.jpg   Getting ready to install my new BD Exhaust Brake-img_2860.jpg   Getting ready to install my new BD Exhaust Brake-img_2861.jpg
Thread Thread Starter Forum Replies Last Post
Getting ready for turbo install. jhenson 3rd Gen High Performance and Accessories (5.9L Only) 5 02-27-2010 08:06 PM
Getting ready to buy new truck Chief Engineer 3rd Gen Engine and Drivetrain -> 2007 and up 11 01-22-2008 04:57 AM
Getting ready to get ready for the BOMB ROCKNRAM Performance and Accessories 2nd gen only 8 12-03-2007 02:19 PM
Getting ready to install HG, What do I need? thewished 12 Valve Engine and Drivetrain 17 11-14-2007 04:08 PM
Getting ready for new clutch drafalske 24 Valve Engine and Drivetrain 3 05-23-2003 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2011, DieselTruckResource.Com
