Sponsored by:
Sponsored by: DashLynx
2006-3500-5.9-Diesel-90000 miles
Old 11-25-2015, 12:22 AM
AKPhil's Avatar
My truck recently developed vibration near front of motor, sounds like the fan shroud.
With the engine off the fan blades are not touching and all seems tight. It runs great except for the vibration. I'm guessing a bearing, fan clutch, or water pump failing.
Any suggestions?
Old 11-25-2015, 10:21 AM
ssandlin's Avatar
Maybe check the fan belt tensioner pulley?
Old 12-01-2015, 08:57 PM
mykaos's Avatar
Take a close look at the fan hub bearing.
Old 12-04-2015, 09:49 PM
AKPhil's Avatar
Thumbs up Vibration found.
My 2006 developed this vibration at 90000 miles. And we all know about hindsight. At the same time I heard the vibrating now I think back on it I also remember loosing my brake retarder.
So I took my serpentine belt off looking for no vibration when restarted and she ran smooth. All pulleys and bearings were tight. With belt back on, fired her back up and put large screw driver against various belt drives and vacuum pump made the most noise.
I ordered a remanufactured as Dodge wanted 825.00. Came in this week. Loosened belt and installed, life is good again.
I hope this helps someone. I really appreciate this website and you Dodge owners knowledge.
jfisher04
15
01-31-2007 08:32 AM
jfisher04
01-26-2007 07:33 AM
N5IBM
06-03-2006 12:00 PM
DanTana
03-06-2006 05:56 AM
Quick Reply: 2006-3500-5.9-Diesel-90000 miles
