Strong dpf smell
Old 04-24-2012, 06:09 PM
brattboy's Avatar
Strong dpf smell
I have a 2008 6.7 Megacab ...whenever the dpf goes throught the burnoff there is STRONG smell inside the cab. Anybody ever have this problem. Of course the dealership has never heard of this before.
Old 04-24-2012, 11:36 PM
johnh's Avatar
the cure is to delete
Old 04-25-2012, 07:46 PM
brattboy's Avatar
strong smell
I would love to but its hard to get around emissions BIG fines for polution control equipment removal!
Old 04-30-2012, 08:24 PM
C/PRD/'s Avatar
Drop the exhaust and disassemble it all. Then with a good piece of 1" angle iron ground to a point you can drive it right down through the cat, then the N02 and the dpf. Reinstall your newly ventilated all oem exhaust and follow up with a smarty jr and your disgusting regen scents will be gone.
That's the cheapest way I know of.
Also you may want to check the manifold and egr to manifold bolts. They always seemed to back off on my 07.
Old 05-01-2012, 10:16 PM
brattboy's Avatar
strong dpf smell
if I gut the dpf will it still pass emissions?
Old 05-02-2012, 01:53 PM
"California Style"
mega-engr's Avatar
That's the funny part. With the basic deletes, mine passed the functional test no problem, but failed the visual... I had to bolt the junk back on to pass the visual only. So, I'd say you have a very good chance to pass the visual and with the stuff stealthly disabled and with a programmer (I had my smarty set to SW3) should be no problem...
Old 05-02-2012, 01:54 PM
"California Style"
mega-engr's Avatar
I would still never guy my stock equipment though. Way too expensive to thrash like that. I'd rather bolt and un-bolt...
Old 05-02-2012, 02:50 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Sounds like exhaust leak somewhere, I would start by tightening clamp on turbo outlet. Torque to 12 ft lbs. Check egr crossover pipe and check clamps and tighten if loose. Check for any black soot on exhaust manifold. May need mirror and flash light to check really well. Check exhaust tailpipe for any black soot, if any soot on inside of tailpipe then DPF is cracked internally. Covered under warranty until 100k miles
Old 05-02-2012, 06:32 PM
brattboy's Avatar
strong dpf smell
thanks for the tips......of course i will have to try to fix this myself. Tired of the trips to the dealer 4X in 4 years called Chrysler they said they would get back to me....ya 2 years ago.
there is no black soot, i wish there was my nice big exhaust tip looks terrible (rusty)
deezulsmoke
20
11-29-2010 07:06 PM
CTDowerTN
03-22-2007 05:09 PM
donhov
08-16-2006 10:48 PM
Eskimo
11-17-2004 10:02 AM
big b
02-04-2003 05:55 PM
Quick Reply: Strong dpf smell
