Egr and cooler cleaning procedure
Old 02-02-2011, 08:14 PM
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
I hope this works. Blake or any other admin, can you sticky this for members review so they can complete the process and save money?
Thanks
Chris
File Type: pdf
Old 02-02-2011, 08:22 PM
Administrator/Jarhead
madhat's Avatar
I got it for you, buddy. Good lookin out.
Old 02-02-2011, 08:38 PM
cbrahs's Avatar
thanks guns!
Old 02-02-2011, 09:39 PM
"California Style"
mega-engr's Avatar
Awesome! Thanks Cbrahs and Admins! Not only is this helpful to those in need, but also educations for those curious about the emissions in the engine compartment and/or looking to do this maintenance themselves in the future .
Old 02-03-2011, 08:33 AM
jswar's Avatar
Gentlemen - Thank you!!
Old 02-13-2011, 09:29 PM
Navy7797's Avatar
??? confused
Now I'm confused, If deletes are done would you have to clean the EGR cooler and valve ? Nothing should be going through there I thought?
Is there some info on how to change the CCV filter ?
Old 02-14-2011, 09:11 AM
cbrahs's Avatar
well if the egr and cooler are gone then they should be pretty clean already. this is only a procedure for STOCK trucks.
Old 02-14-2011, 09:17 AM
cbrahs's Avatar
Exclamation forgot to post reset procedure!!!!!!!!!!
ok forgive me but I forgot to add the reset procedure for the perform service light. SORRY!!!!!
PERFORM SERVICE INDICATOR - RESET The “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure: 1. Turn the ignition switch to the ON position (Do not start engine). 2. Press and release the brake pedal two times. 3. Fully depress the accelerator pedal slowly two times within 10 seconds. 4. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
Old 02-14-2011, 09:19 AM
cbrahs's Avatar
the ccv filter is easy, remove plastic outter valve cover. there are a few bolts holding the filter in place. remove filter and install new one and re-install valve cover. it is a 4 tenths hour job.
Old 02-14-2011, 09:27 AM
whiteeye42's Avatar
i tried to go to the link you have in the maintenance guide you posted the link is titled
see: Removal\Replacement\EGR cooler the link takes you to a site called alldatapro and you need a logon name and password to access it is there some way to bypass the logon and password because there is no way to access the info with out it
Old 02-14-2011, 09:30 AM
cbrahs's Avatar
you can't click on the hyperlinks on the file that I posted unless you have log in access. i thought I removed them but looks like I didn't.
removal of the egr cooler is a 15mm wrench on the outside bolt, a 15mm socket with 3" extension reaching into between valve cover and cooler, a 11mm deep socket to remove v-band clamp, drain coolant. remove rubber hoses, pull cooler. its pretty simple
Old 02-14-2011, 09:45 AM
whiteeye42's Avatar
ok thanks
Old 02-14-2011, 03:47 PM
Navy7797's Avatar
Info
Thanks for the info cbarhs, thats what I needed to know.
Old 03-08-2011, 07:39 AM
jdinny's Avatar
Great info
Semper-Fi
Old 10-30-2011, 06:03 PM
rpdsnow's Avatar
Thanks Chirs worked out good & saved a lot of money. Thanks again rpdsnow.
Quick Reply: Egr and cooler cleaning procedure
