View Poll Results: When did your water pump fail?
Never flushed and it failed
76
45.51%
With-in 5k miles of MOPAR HOAT
2.40%
With-in 5k miles of aftermarket antifreeze
4.79%
After 5k but prior to 50k miles of any flush
21
12.57%
After 50k miles of any flush
58
34.73%
Voters: 167. You may not vote on this poll
Water Pump failure poll, when did yours fail?
#62
510,000kms on the same water pump, not sure what AF was in there before I switched to Amsoil at 300,000kms.
after removing the water pump it appeared as if it was an o-ring failure(no leaks at tell tail hole) I installed a new pump anyway, I fiqured it was long over due
#63
Mine is sitting at the dealer as I am typing. 78,000 miles. No leaks or anything. Drive to the store, and when i came out, a puddle of coolant. Drove home and took a look. Sure enough it was the pump. Waiting on a pressure test this morning and the rep. is suppose to call. Should be covered under warranty. Only have 4 months to go.
#64
I have 322,600 on my truck and have been through 4 pumps. The oem failed @220k and replaced with one from car-quest. This one failed @ 30k and they replaced it. That one lasted 71,870 and they replaced it again. I'm hoping to get @60 or 70k out of this one.
Jim
Jim
#66
First one failed at 85,000. Had new pump replaced by dealer. Dealer flushed and refilled system and I assume they would use HOAT formula coolant. Dealer pump failed at 160,000 miles. I Replaced the dealer pump with the help of a friend that is a mechanic at a national service center. We used a Napa pump and he used the "mixes with anything" coolant to replace what was lost during the change. We did not flush the system or change coolants. I realize now this was not a good plan. Now, the Napa has failed at 245,000. Replacing it with another Napa ($50) this weekend. I am flushing the system and replacing with Zerex HOAT coolant.
#69
Mine came apart on hwy going around big curve on IH 10 lost the serpentine belt power steering and all no previous indication it was going out it just came apart at about 80,000 miles on the ticker. Scared me had no power brakes or anything.
#71
Pump life
Had 76K and pump started to leak.Luckily it was 1 month BEFORE my warranty expired and dealer replaced pump[was not happy to have to do it under warranty].I also have a coolant filter so I have not changed my coolant yet.
#73
Not sure why the dealer would be unhappy. It's not like it's a costly part NOR is it labor intensive. Probably one of the least expensive things to do to a Cummins.
#75
Started dripping at 70K.
Replaced at 84K
Replaced at 84K
