View Poll Results: When did your water pump fail?
Never flushed and it failed
76
45.51%
With-in 5k miles of MOPAR HOAT
2.40%
With-in 5k miles of aftermarket antifreeze
4.79%
After 5k but prior to 50k miles of any flush
21
12.57%
After 50k miles of any flush
58
34.73%
Voters: 167. You may not vote on this poll
Water Pump failure poll, when did yours fail?
#156
Water pump on my 03 5.9 began leaking around 100K ... not long after the cooling system had been flushed and the coolant replaced with "Peak (HOAT) Global Lifetime"
#158
271k and mine just failed... But had a customer's truck here, 03 with 67k on it for a water pump last week. I always have one on the shelf just in case, good thing I did because I needed it for me haha!
#160
2012 Dodge Ram Cummings
I purchased 3 trucks in 2012. A 3500 duelly. A 3500 crew cab. A 2500 crew cab. All 3 water pumps went out at 60 k. And I'm talking about within 2000 miles of each other.
We are very strict on our maintenance too. I replaced my only duramax trucks water pump once and it's got 500k on it.
I'm looking to buy 2 more trucks this summer and this isn't sitting well with me.
#161
Dodge just needs to dissect the Dura's pump and replicate it. Spec out the pump better.
The shop I use sees failure of the seal to be the most prominent issue.
On the other hand,they had a Dura @ 78K needing new injectors. That's booked out @ 15hr shop time. This was a 2005.
Water pumps do go out on them but way less frequently. Book time is 4-5 hrs as I recall.
#162
150k on my 03 now and currently on my 3rd WP! Went with an aftermarket WP (w/lifetime warranty of course) after the OEM seal failed. If anyone's wondering...yes...I used HOAT compliant/Peak Global Life AF on the refills every time. Fortunately swapping pumps on this particular year is easy enough and with so many failures, I can pretty much swap a pump in my sleep
Kurt A. Hesse (01-26-2017)
