Sounds like a midget with a kazoo is behind my dash
Old 11-17-2014, 06:27 PM
marder's Avatar
Drivin home in 40 mph wind and the dash just starts screaming. I thought the fan was seizing up so I turn it off and that made no difference. Slowed the truck down and it stopped. Sped back up and it started again. So my question is when the blend door breaks does outside air hit it somehow? My heater has been weak lately.
Old 11-17-2014, 08:27 PM
kerry.king's Avatar
I have no idea what the problem is, but your thread title is hilarious!!!
Old 11-17-2014, 08:37 PM
Administrator/Jarhead
madhat's Avatar
I think the blend door has broken and air is blowing in and moving something...
Old 11-17-2014, 10:30 PM
Received 1,637 Likes on 1,112 Posts
I thought the same thing. Then I thought...
Some people have to pay extra for that feature, and this guy is complaining about it....
Geesh !
Old 11-18-2014, 05:08 PM
shep1's Avatar
Maybe a leaf stuck in the air flow somewhere acting like a reed in a KAZOO.
Old 11-20-2014, 08:36 AM
HMX-1's Avatar
Laughing ......
Yes it's a blend door, one (or more) of the four is broken. We had our replaced under warranty on our '06 around 36k miles but they're broke. Again.
Look at the Heater Treater replacements, you're supposed to be able to replace them without removing the dash.
Letting the dealer do it will run you about $1400 bucks.
-Kris
Old 11-20-2014, 10:48 AM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
You didn't just come back from Mexico did you?
Attached Thumbnails Sounds like a midget with a kazoo is behind my dash-dashboard1.jpg   Sounds like a midget with a kazoo is behind my dash-dashboard2.jpg   Sounds like a midget with a kazoo is behind my dash-dashboard3.jpg
Old 11-20-2014, 12:38 PM
railroaderone's Avatar
I knew they were creative with hiding stuff be gees
Old 11-20-2014, 12:46 PM
Jeff in TD's Avatar
Does yours have the updated hose between the power steering pump and brake booster?
I had an 03 that had a kazoo like buzz (my words too) only at 2000 rpm. Went in under warranty and they checked hvac and padded a bunch of stuff- didn't fix it.
I mentioned the TSB about installing the new version of that hose to cure complaints of buzz in the column or pedals, and that fixed it.
The older style hose is plain, and the updated part has a metal restriction and a large metal weight mid-span.
Old 11-20-2014, 04:55 PM
marder's Avatar
I'm not sure, ill have to check that. Thanks for the tip.
cstewart
NCDTR #18
05-31-2013 12:43 PM
hamilton71801
12-22-2009 12:55 PM
NoSparkplugs
17
05-17-2009 10:36 PM
tool
04-07-2008 07:49 AM
steveb
17
01-24-2004 10:15 PM
Quick Reply: Sounds like a midget with a kazoo is behind my dash
