04 headlight problems pdc or fcm ?
Old 01-22-2017, 11:17 AM
booman70's Avatar
my problem started a few weeks ago with the plow head light passenger side going out but would flash alternately with right turn signal. disconnect plow truck was fine for about a week then passenger truck head light went out all bulbs are good. disconnect batteries for a bit worked good for about a week then same thing. remove pdc(fuse box) and fcm(front control module) clean up with electrical cleaner all is good for a dew days then same thing again. I have pulled the pdc apart can't find any bad spots reassemble and now no high beam on drivers side only one low beam. disconnect batts and fcm once again then i have both low beams no high beams pull a few fuses and i lose drivers side only passenger low beam now. every time i try to figure this out the problem changes to different headlights working. all the bulbs are good and i have completely disconnected the plow lights just the truck headlights are connected. i have read every thread i can find and am not sure which to try first pdc or fcm
HighTen
08-27-2016 09:39 AM
jmlcolorado
0
09-28-2014 07:01 PM
dmfish
11-23-2012 09:26 PM
realsquash
03-08-2011 04:22 PM
alwaysfaded
04-04-2007 08:37 PM
Quick Reply: 04 headlight problems pdc or fcm ?
