Wont start when cold
I have recently been having trouble starting my truck which has 350000 miles on it when the outside air temp is in low 40s and colder. If I plug the block heater in for about an hour it will start. I recently had a new injector pump installed and I can also hear the lift pump run for several seconds after I bump the starter. Thinking it could be a problem with the grid heater but I also believe the truck should start in mild temp without the grid heater. Any suggestions?
You got 350,000 on them....that's a good run!! Not fun dropping $2000+ but at those miles, it's a safe bet it's the injectors.
Whatever you do, do NOT buy remanufactured injectors....buy new. I sourced mine locally. Good luck!
bigfish95971
13
01-22-2011 08:22 AM
joeel
12-06-2006 09:22 PM
