repair fan clutch wiring?
Old 05-31-2015, 08:49 AM
anpconnors's Avatar
anyone repair the wiring for the fan clutch? Mines broken at the clutch end very close to the connector. Emailed Hayden. Anyone dissect the clutch? A/C not working since all wires are cut to clutch. Thanks!
Old 05-31-2015, 10:36 AM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Chrysler has repair kit for wiring connector. I just replaced one recently, call parts they can order one for you.
Old 06-01-2015, 01:01 PM
anpconnors's Avatar
Repair kit part# ?
Thanks for the reply, do you remember if the Mopar kit was to fix the bottom or top end of the harness, hub or ecm end? Hayden replied they do not sell the harness. Part # ? Thanks!
Old 06-01-2015, 02:36 PM
anpconnors's Avatar
Mopar connector site
Found Mopar Connection Repair Kit
and it lists #68052582AA as a kit and looks like the connector @ the bottom by the ECM. And they are too pricey ($58), would rather attempt to repair wiring.
Thanks!
Old 06-22-2015, 03:43 PM
anpconnors's Avatar
Purchased new fan clutch. Tried three auto stores for the 36 mm fan wrench, all too loose. Purchased the Craftsman Kit, new, and on 1st try the wrench slipped and rounded off the nut...argh. Tool opening measures 36 mm on one side and 37 mm on the opposite side, opening is tapered?? Reluctant to use air chisel, will it damage water pump? 123K miles on original pump.
Old 07-04-2015, 08:02 PM
anpconnors's Avatar
Purchased Lisle air chisel set. replaced fan clutch. New clutch works great. A/C still fubar. tried the battery trick on the switch and compressor did not turn on. Ordered pressure switch and compressor.
Old 07-05-2015, 01:44 PM
scuzman00's Avatar
Pull the connector off of the pressure switch and jumper it out with a piece of a paper clip. If switch is bad, the jumper will prove that by allowing the compressor to run. I use this trick to charge a low system where the charge is too low to allow compressor to operate.
Gary
Old 07-06-2015, 01:15 PM
anpconnors's Avatar
Jumper pins 2 & 3?
Tried putting 1.5V between pins 1 (ground) and pin 3 (+ positive) and clutch did not respond. Are you saying jumper pin 2 (5V supply) and Pin 3 (pressure signal)?
Old 07-06-2015, 01:31 PM
PWong's Avatar
It's a transducer, not a switch.
Try apply a higher voltage signal between pin 1 and pin 3, may be 3V.
Old 07-06-2015, 01:39 PM
PWong's Avatar
What's wrong with the compressor?
Usually when a compressor goes bad you have to replace the orifice tube and dryer assembly together with the compressor. Make sure flash clean the WHOLE system.
If clutch is bad and compressor is good you can just do the clutch.
Old 07-06-2015, 01:41 PM
PWong's Avatar
Did you verify battery power at clutch when you did that?
FamilyDiesel
03-30-2008 05:53 AM
jrs_dodge_diesel
09-28-2007 11:38 AM
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
big jimmy
07-07-2006 01:33 PM
Quick Reply: repair fan clutch wiring?
