Mark this thread as Unsold
Performance & Accessories 3rd Gen 64/71/13SS Turbo and Manifold
I have an HTT 64/71/13ss turbo and ATS 3rd gen T3 exhaust manifold for sale.
The turbo had 60k miles on it, and now has zero miles after new bearings and seals were installed. It never had any issues, just wanted to have it "freshened up" since it was off. It does have the upgraded 13cm2 stainless steel turbine housing and spring-gate set at 41psi. The compressor wheel is the 64mm extended tip, and the turbine housing is the 71mm wheel. I really like this turbo for supporting good power, without excessive lag and surging issues. It works well all around. It is setup with the 3rd gen compressor outlet, and the turbine housing is machined to work with the factory exhaust elbow so it drops right in. There are no cracks, ect. It is ready to install and enjoy!
The exhaust manifold is a direct replacement for the factory 3rd gen manifold. It is in good shape, had no leaks or cracks, and ready to run for many more miles. Manifold is drilled and tapped for a pyrometer.
New turbine inlet gasket and oil drain gasket are also included.
Original cost on the turbo with upgraded wastegate was $1850 and the manifold was $470 for a total of $2320.
Price for turbo/manifold package: $1149. Shipping negotiable.
Fire Rescue124
10-09-2009 11:20 AM
Jason_K
13
05-11-2009 08:55 AM
O.T
16
01-14-2008 02:47 PM
95ram12v
01-13-2008 07:48 PM
