water pump routing
water pump routing
All,
I started a 1995 Ram 4x4 restoration project, and have swapped the auto for an NV4500.
There is what seems like an "expansion chamber" under the exhaust manifold that hooks up to the water pump. Is this for cooling the auto transmission, or does it serve another purpose? I'm eliminating everything associated with the auto transmission, and methinks this is for the aborted auto.
Thanks from a novice!
Cummins Guru
Auto trans cooler, do not need it with manual trans. Do not forget to install pilot bearing with the replacement manual trans.
Buckshotmckee
01-02-2005 08:19 PM
dcorneli
04-25-2004 08:44 AM
surfram
02-12-2004 07:20 AM
