Wiring Diagram Help
Old 12-11-2014, 11:51 AM
Zeb Christensen's Avatar
Wiring Diagram Help
I am in need of a place to get wiring for the tail light on a 94 Dodge Ram 2500. The tail lights do not work, and are the only thing that don't work.
Any help would be nice, Thanks
Old 12-11-2014, 01:03 PM
Rons red Ram's Avatar
Do the license plate lights work? Everything is tied together coming from the headlamp switch. I've got a later 2nd gen diagram so the color may be off, but it shows the power coming from a black wire with a yellow stripe.
Old 12-11-2014, 01:16 PM
I forget to mention that it has a flatbed.. Need to know where to start looking for power. Thanks
Old 12-11-2014, 01:19 PM
Maybe the easiest place to start looking is to pull the headlight switch and pop the connector off to see if it melted. Wouldn't be the first.
Old 12-11-2014, 01:24 PM
You think so even if every thing working except the tail lights
Old 12-11-2014, 05:27 PM
patdaly's Avatar
Here is some of the info of a 95, should be the same. There is more but to post it all would be huge.
I can highly recommend getting a factory service manual on CD, from genos Garage, 35 bucks here, saves your bacon many times over.
1994 Dodge Ram Factory Service Manual - CD Version-Geno's Garage
Old 12-11-2014, 07:11 PM
Thank you very much for the diagrams. What all does the service manual include, does in include engine repair specs and other such things.
Old 12-11-2014, 09:42 PM
So I checked the headlight switch and that is not to the problem. It's not melted and I put a jumper wire to the black with yellow tracer and all the front marker lights still work but still no taillights. I looked at the above diagrams but there is no location of the connectors, and was wondering where they might be.
Thanks
Old 12-11-2014, 09:51 PM
There aren't that many connections. The harness comes out of the firewall and down along the left frame rail.
Pull a rear bulb and check at the connector. Check continuity of the ground to the chassis, then see if you have 12 volts. One is missing and go from there.
Old 12-11-2014, 10:08 PM
Already put a jumper wire to the back and the lights work then so like have to find so time to chase wires
Old 12-11-2014, 10:12 PM
Only connections in the rear are each light inside the frame and a ground.
Next connection should be in the cab. That's why I suggested start in back. See what's there or not there inside the bulb socket.
Old 12-11-2014, 10:21 PM
Would it be in the cab or like bulkhead connector going through the fire wall
Old 12-12-2014, 08:02 AM
patdaly's Avatar
Everything that a factory Chrysler tech could need. It is VERY detailed. For instance, the 95 manual is 1,754 pages.
Saved my bacon time after time, especially with the diesel, way too many mechanics who haven't a clue.
Airslide
15
03-28-2012 07:43 PM
rjmelehan
06-06-2011 05:14 PM
bigbaddiesel416
03-01-2009 09:24 PM
HydraulicGuy
02-28-2004 04:19 PM
Stevenc
11-21-2003 09:05 AM
Quick Reply: Wiring Diagram Help
