HELP!Wheel stuck
HELP!Wheel stuck
OK so recently I've had some brae issues where the brake light & abs would come on & then no brakes but only while in park.I've noticed that both of the wheels were getting hot so figured stuck caliper was going to do the brakes today.Then while on the way home to work I heard a bad squealing on pass side wheel next thing I know that wheel locked up.Took the caliper off still could barley move it.
Seems as if I move the hub/rotor backwards it moves easier.Both wheel's in the front look like this /\ pass side being worse.I have recently replaced tie rods,track bar ,steering stabilizer etc.So I figured that was just because I needed an alignment.Mt other Cummins is still down so I need to fix this.The big nut that holds everything on there looks like it's been pulled back in some by the way it looks behind the nut.I will try to post a pic .I'm worried it's something in the axle.Any suggestions? There was metal shavings on the top of the caliper cannot tell where it came from?Last nite while trying to pull out of a tight spot it felt like I had no power steering.Any help would be great appreciated thanks.
Hub bearing took a dump, most likely. Or your ball joints are really bad, with the wheels off the ground see where there is any play. Just up and down would be ball joints, as all directions would be hub bearing.
Hub bearing is bolted into the steering knuckle 4 x 9/16 12 pt. bolts through the back. Do a search on complete procedure of changing them if they're bad.
If the axle nut loosened up because of no cotter pin the bearing self destructs and needs replacing.
Check brake fluid level also.
samaf (12-03-2016)
birdboy
12-12-2018 09:02 PM
birdboy
04-21-2012 09:44 PM
