HELP 2001 cab change
i just bought an 01 cummins, the guy i bought it from lied and said it was an original 24v switched to a low mileage 12v, the title matches the body, but i looked the numbers up and this truck was original a 360 gasser. i need to buy a parts truck with a good cab and matching title, how hard will it be to replace the cab? the truck itself is in great condition, it just cannot be registered. the engine and tranny are from a 95, they also replaced the dash with a 95, is it worth it? i figured id put the interior thats in it now in the new cab. ive never replaced a cab so how hard would it be? what are my steps? i have the equipment to do it, forklift etc, im not sure if i should replace the cab on this truck or put the drivetrain in annother truck.
Actually all you "need" to do is get a rusty 95 Body/title with a diesel and change out the dash, I doubt they would go any further looking for vins.
You say the title matches the VIN tag on the dash?
the vin is on the metal dash (attached to the cab itself) not the dash pad. but there is another vin on the driver door jam (same as the one by the dash) which the title matches. only problem is the title says "8 cyl" meaning it was originally a gasser. i think i'm going to buy a cab with a clean title and replace my cab.
the tag on the dash is definitely mounted to the metal, and it matches the title as well as the door jam numbers i just looked at it. my good friend inspects vehicles, he told me today that switching tags is considered fraud and can result in fines and impound, ive found a decent parts truck, everything is there except the engine and tranny and bed, im looking at it next week, and ill either make a good truck out of the two of them, or just put that cab on my truck. my headaches have gotten much bigger these last few days, but it should all work out...
Ok, if it is attached to the metal, then a previous owner has done it, making it that much more of a problem.
94 Cab will bolt on fine, parts books show no difference in floorpan between 4X4/2X4, Gas or Diesel.
rattlebox01
11-06-2009 12:28 PM
