Heater Selector Control Knob - Dodge Diesel - Diesel Truck Resource Forums
Thread Tools Search this Thread
Old 09-05-2012, 09:33 PM   #1
Heater Selector Control ****
Is there a good location to purchase a new heater selector control ****? I have JB Weld the metal clip to the plastic a few times, that is only a temp fix, eventually this breaks too. Figure I would just replace the ****, just don't know if there is a preferred site to purchase from.
MrKen is offline   Reply With Quote
Old 09-06-2012, 08:05 AM   #2
They are cheap from the dealer, or at least used to be. I found a Chrysler that used the same ****, can't remember the exact one, but it was mid to late 90's that had the same **** in the junkyard. It was from the full sized sedan, new yorker perhaps? I think the Intrepid also had the same one.
patdaly is offline   Reply With Quote
Old 09-06-2012, 11:34 AM   #3
I replaced mine a couple times before I figured out to slip a tight fitting short piece of copper tubing over the plastic part that always cracked to strengthen it.
Problem solved for now for 14 years.
infidel is offline   Reply With Quote
Old 09-06-2012, 04:02 PM   #4
SIXSLUG's Avatar
I've got three for a 98.5+ if you think it would work......
I can't remember what Dad's 94 ***** look like!!
SIXSLUG is offline   Reply With Quote
Old 01-31-2017, 11:34 AM   #5
That's good information ! Even if it's an old thread
Ron E is offline   Reply With Quote
Old 02-01-2017, 01:04 AM   #6
I used some braided fishing line and some epoxy and wrapped the fishing line around the cracked part and epoxied it. Got 3 years on that fix and all is still well.
Robert Rausch is offline   Reply With Quote
Old 02-01-2017, 08:11 AM   #7
A pick and pull type junk yard. The ***** are on a lot of vehicles.
VADSLRAM is offline   Reply With Quote
Old 02-01-2017, 10:26 AM   #8
It's an old thread but I might point out that at some point, 1995-1998 the heater control was changed from a Bowden cable operated system to an electrical rotary drive system so while the switch panel is the same the actual heater control switch is different.
Busboy is offline   Reply With Quote
Old 02-02-2017, 12:40 PM   #9
97 for sure is cable, so I bet it changed in 98
The Following User Says Thank You to patdaly For This Useful Post:
Busboy (02-02-2017)
Old 02-02-2017, 04:39 PM   #10
Good to know.
Thread Thread Starter Forum Replies Last Post
Top heater /selector control knob bent leeboy 2nd Gen. Dodge Ram - No Drivetrain 5 02-21-2015 12:15 PM
Heater and A/C control temp knob Gator4 3rd Generation Ram - Non Drivetrain - All Years 1 01-30-2012 11:30 PM
Heater Control Knob? atc250r 2nd Gen. Dodge Ram - No Drivetrain 8 10-15-2010 10:37 AM
Cruise control / Heater vent selector daddy mopar 2nd Gen. Dodge Ram - No Drivetrain 7 12-31-2008 06:52 PM
Heater Control Temperature Selector? - Replacing Coolant EverydayDiesel 24 Valve Engine and Drivetrain 3 06-22-2007 08:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2011, DieselTruckResource.Com
