Fitting to replace banjo bolt, what size?
Old 06-08-2007, 07:44 AM
Tommy93w350's Avatar
I need to replace my LP again. These time I'm installing a Holley Blue and moving the pump to the frame. I need the banjo fitting size so I can replace it with a barbed fitting and rubber hose lines.
Also, does the holley have to have a regulator?
Old 06-08-2007, 03:19 PM
Sea:\>Drive's Avatar
Take the new lift pump with you (I think it is metric) and the barb should just match the fuel line (be sure it is diesel rated). Some use 3/8" some use 1/2"
Old 06-09-2007, 12:44 AM
DL1221's Avatar
The banjo bolt is metric, 12mm. The only place I've seen a 12mm barbed fitting is here, at Vulcan:
http://www.vulcanperformance.com/ser...2%84%A2/Detail
Good luck finding it locally.
For hose, use 3/8 diesel rated rubber hose, not the regular fuel line that gassers use.
Vulcan has some good hose too:
http://www.vulcanperformance.com/ser...ine/Categories
Old 06-09-2007, 08:32 AM
D2 Cat's Avatar
The Vulcan kit includes everything, hose, fittings to replace banjo to get better fuel flow all the way to the IP for a little over $100. Every thing to relocate your pump on the frame and have 1/2" line without banjo to your pump.
Old 06-09-2007, 08:57 AM
DRD
DRD's Avatar
I just did the Vulcan kit. You could find all the pieces yourself and get it a bit cheaper. For me the convenience of having everything I need show up in a box rather than driving all over looking for what I needed, was well worth the hundy bucks or so.
Old 06-09-2007, 10:02 AM
Devin_01's Avatar
What i did with my lift pump is took it apart and drilled the inlet and outlet and tapped it to NPT Threads. I also did this to my fuel filter canister to get rid of those banjo bolts.
Old 11-16-2016, 06:40 AM
Gizmo52's Avatar
Do you remember what size tap you used for the banjo bolts? I'm looking to do 1/2 inch line from the tank to the injection pump with the in tank fuel mod which would replace the pickup with 3/8 hose and keep the stock in tank screen anlong with the stock filter and lift pump. I want to do this all now so I can eventually do the walbro 392.
Moobesor
07-15-2008 03:07 PM
ataboy9026
06-18-2007 09:04 PM
8mpg
06-15-2007 07:38 PM
Quick Reply: Fitting to replace banjo bolt, what size?
