Engine/exhaust braking - Dodge Diesel - Diesel Truck Resource Forums
Thread Tools Search this Thread
Old 01-30-2017, 05:34 AM   #1
Question Engine/exhaust braking
I'm on the road and want to use the torque converter lock out for additional braking. Will I damage anything on my automatic (46re I believe) by doing this? Still have a braking issue and want to minimize their usage. Pulling a 5th wheel at about 10,000 lbs.
cohocoal is offline   Reply With Quote
Old 01-30-2017, 08:38 AM   #2
AlpineRAM's Avatar
You mean torque converter lockup.
And you do not want to do it. The pressure that holds the torque converter lockup applied is depending on the throttle position. Therefore with the loud pedal in the air there is extremely low pressure to keep the converter lock applied.
Some folks get away with it for a time, but with an exhaust brake you will overpower the lockup clutch.
Some time ago there was a kit that pulled the trhrottle valve cable for you when using an exhaust brake- this should go in the right direction for what you want.
AlpineRAM is offline   Reply With Quote
The Following User Says Thank You to AlpineRAM For This Useful Post:
cohocoal (01-30-2017)
Old 01-30-2017, 09:00 AM   #3
KATOOM's Avatar
If you want the advantage of an exhaust brake with those auto's then I'd suggest going with at least a new torque converter and valve body, as well as finding the right lock up kit.
KATOOM is offline   Reply With Quote
The Following User Says Thank You to KATOOM For This Useful Post:
Old 01-30-2017, 11:28 PM   #4
Thanks I will not use anything except my brakes. I don't need to open the transmission to possible problems at this point. Sounds like an exhaust brake may also prove challenging to find. That will come this fall..
Old 01-31-2017, 12:05 AM   #5
KATOOM's Avatar
I feel like I left you uninformed by not also telling you how important an exhaust brake is while towing. My opinion is it should be required to have an exhaust brake while towing with a diesel. So the advantage is well worth going through the trouble to install one and make sure the transmission can handle the retarding pressure. You'll be amazed how well they work while towing downhills.
Old 01-31-2017, 10:37 AM   #6
Quote:
Originally Posted by KATOOM View Post
..................You'll be amazed how well they work while towing downhills.
Big ditto to that!!
Robert Rausch is offline   Reply With Quote
Old 01-31-2017, 02:21 PM   #7
SIXSLUG's Avatar
Exhaust brake is definitely on my list for heavy towing.
SIXSLUG is offline   Reply With Quote
Old 01-31-2017, 04:02 PM   #8
AlpineRAM's Avatar
Yep, an EB is really worth having, especially when you tow or haul.
But: It is an extremely bad idea to just install one (about 700-100 US$ AFAIK) and then not to adapt your automatic transmission correctly.
OK, this costs another bundle, but it will avoid you having the tranny give up right in the middle of a descent and free-wheeling down the mountain and then having to order a tow truck.
The system I meant was really rather primitive, it was a small pneumatic cylinder that pushed the throttle valve lever on the tranny in the same direction it is pulled when you step on the go pedal.
The tranny uses this information to regulate itself to cope with the torque the engine delivers- low throttle low torque, open throttle high torque. The tranny does not care in which direction the torque is applied. (power or braking).
(I have built such a "thing" with parts sourced locally for a friend who tows his excavator over here in the alps- I just teed it into the air line that activates the exhaust brake- which came from a scrapyard and fit right into the 4" exhaust)
Thread Thread Starter Forum Replies Last Post
47re engine braking ? DodgeFreak 24 Valve Engine and Drivetrain 5 08-04-2012 11:40 AM
Engine braking dilemma? D Nut 12 Valve Engine and Drivetrain 20 11-08-2010 05:27 PM
Beginning year of factory installed engine braking? D Nut 3rd Gen Engine and Drivetrain -> 2003-2007 9 11-04-2010 05:02 PM
Check engine light on after power braking. Clint S. 3rd Gen Engine and Drivetrain -> 2003-2007 7 10-03-2006 09:11 AM
Finally had the engine-braking/ cruise problem 03quadduallyho 3rd Gen Engine and Drivetrain -> 2003-2007 2 03-24-2003 05:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2011, DieselTruckResource.Com
