engine dies when you put in drive the truck
Hi folks, I have this problem I have a 95 dodge ram 12 valves, the idle is ok, but when you change to Drive if you no press fast the gas pedal the truck die; the rpm in parking is 500-600rph.
Any Idea, can just adjust the rph
Is this a 12v or 24v? Because adjusting the idle on a 24v is not advised because you'll easily change the parameters of the APPS, and there's a TSB about this problem which I believe is fixed with a re-flash.
Nope, usually just time and wear on the linkage. It can also be low injection pump pressure, dirty fuel filter, clogged pre-filter, bad lift pump, bad overflow valve, but usually just a simple adjustment..........
The throttle linkage wears a groove in the idle adjustment bolt over time so the idle drops...usually it doesn't take much more than turning the adjustment bolt 90 degrees to bring it back within specs so it no longer lands in the groove worn in the bolt head.
Totallyrad
11-29-2010 02:34 AM
RockysInMyBlood
11-17-2008 10:22 AM
DynamicalyUnstable
11-13-2008 09:36 PM
